How Check OC config.plist Configuration if it's valid for testing on a VMware virtual machine instead of a physical computer
Nikos365
Levovo V-110
intel i3 60060U
intel Graphics 520
10.14.x
Hello
Is it possible to make a config.plist file according to Dortania's GitHub documentation, and after this insert the USB stick drive to Vmware virtual machine and check if it's bootable instead of trying to boot the USB OC boot drive to a physical machine. This way, I can avoid the OC stuck on the machine with a black screen or wrong configuration...and avoid also to make harm on my computer by hard rebooting it
Any related answer would be appreciated
Thanks
Hello
Thanks
Well, installing on VMware requires different steps.
What's the host specs?
Reactions: Nikos365
Here are Hosts Spec's :
AMD-A10 7850k 4Cores
16GB DDR3
SSD 128GB
ASROCK A-68 FM2DG3+
AMD ASUS STRIX RX480 8GB
16GB DDR3
SSD 128GB
ASROCK A-68 FM2DG3+
You can install it as a bare metal.
fierofree
