I225-V Problem
Rakan05
Z490-E
I7-10700K
RTX 3060
Hello , I want to install Ventura using opencore
When I click Reinstall MACOS it said not internet access
Also Vt-d is disabled and here is my EFI folder
Moreover, you should remove the Device Properties for Intel I225-V as Ventura has a native support. With that, enable VT-d and you should be good to go.
I delete it but im still facing the same problem
sorry , what do you mean by that ?
Read the FAQ:
scoobypetey
