GC titan ridg card can not use usb3.1
cw2200
GIGABYTE z390 master
9900ks
6900XT
Hello,
I am a user from China, and my English is not very good, so I can only communicate with translation tools. I don't know whether the machine translation is accurate, so I can only try to describe my problems. I have found no useful information on the Chinese forum.
Here are the questions I met.
I have two GC titan ridg cards, one is V1 and anthoer is V2
Original firmware used in V1
V2 flshed 5.0 custom firmware
I use them to use my studio display
However, the two cards have the same problem. The USB Docking Station of the USB 3.1 function TYPC interface and the Samsung T7 TYPC SSD cannot be recognized.
I can use Thunderbolt 3 cable to light up the display, but the brightness and sound engineer cannot use it
System report - USB is identified as USB 3.0 bus
I can't find out what caused it. I hope I can get help
Thanks!
Kind Regards
Hello,
Thanks!
Kind Regards
BIOS Settings is wrong and must be in English.
Incomplete PR files attached. Thunderbolt information is missing.
Check the thread linked below for more information on PR files for Thunderbolt
I'm sorry I ignored the Chinese language. I hope I did the right thing this time
  1. Thunderbolt Chip and Family Titan Ridge
  2. Thunderbolt Vendor/Manufacturer GIGABYTE
  3. Thunderbolt Type (Onboard or AIC) AIC
  4. Thunderbolt AIC PCI Slot Location PCI Slot 4
  5. THB_C header Availability YES
  6. TB BIOS Settings Availability YES
  7. Motherboard Model AORUS Z390 MASTER
  8. CPU Model 9900ks
  9. macOS version Ventura 13.1
Thanks again!!!
  • bios.zip
    bios.zip
  • info.txt
    info.txt
  8. CPU Model 9900ks
Thanks again!!!
Your BIOS Settings is not correct and the configuration is not as per the guide.
alvarg82
