 - Dec 7, 2022
 - ASRock H97 Killer
 - Intel Core i7 4790
 - AMD Radeon RX Vega 56
 - 10.13.x
Yes, 840. Looks good. Just click on Apply and you should be good to go.I'm assuming you meant 840 and not 860: this is what I should do?
As it is not. You can clearly see that a container disk5 has a partition with the name Untitled. You must delete that partition.
But after formatting the partition as another format (I chose exFat), you still can't really erase it (unless I'm missing something):Sometimes, it is not possible to delete a volume from a container. In such case, format the volume as a different File System than APFS and then delete the partition.
You should be able to erase the volume. Click on Erase button and the disk should be erased. Once erased, provide a screenshot.But after formatting the partition as another format (I chose exFat), you still can't really erase it (unless I'm missing something): View attachment 5349
That was the goal!It is "erased", but in the sense that it's formatted again, not actually deleted
If you see, there is no option to delete the volume. Try to format the Untitled Volume as APFS. Quit Disk Utility, open it again and provide a screenshot.
