How to Fix Instant Wake on macOS
The _PRW patches can be used to fix "instant wake" where the laptop will not sleep without waking up seconds after sleep begins. Use only "USB _PRW 0x6D (instant wake)" or "USB _PRW 0x0D (instant wake)" as it relates to existing code in your DSDT (also note specific versions of these patches for Skylake and later). You should examine your DSDT to determine what the relevant _PRW methods return to be certain the patch is appropriate for your DSDT.
QUICK NOTE:
  • GPRW, UPRW, and LANCPRW patches will disable sleep from any USB Device. You must wake the system using the Power button.
  • Do not use all the patches together. You should examine your DSDT to determine the relevant _PRW methods and then use the appropriate patch.
Hi, I was wondering what DSDT should I be looking for to determine the patch that is appropriate?
Thanks
Thanks
The DSDT itself.
Reactions: KVyDavid
ANARKRUTOI
