That's because Apple removed AppleIntelCPUPowerManagement.kext from Ventura
The guide will be updated for macOS Ventura soon.
okay. what about monterey.. i tried the patch but it doesnt seams to work.. did i miss something ?
As u can see avg core and turbo is not going down :(
No idea without PR files.
Been trying to get this to boot BigSir ...Not sure what is stopping the process I'm on Clover gave up on OpenCore for now ..I'm Rock solid on Mojave Clover .
Bios is set to default and I'm still getting PM with patched ACPUPMkext.
I have updated all kexts and still KP.
patched PM and nothing seems to get me into boot installer .
I'm sure I have not found the issue ,but would like to ask for someone who really knows what my issue is .
thank you in advance
You don't need to patch kexts. Use Kernel patching on the fly.
1. Mount your ESP
2. Open your config.plist
3. Depending on the bootloader you use, and the macOS/OS X version installed, add the following patches to your config.plist under Kernel and Kext Patches>KextsToPatch (for Clover) and Kernel>Patch (for OpenCore).
4. Once added, save your config.plist.
Not sure how this works
1. Mount your ESP
What's not clear?
Thanks for your Help
"You don't need to patch kexts. Use Kernel patching on the fly."
would you please attach an example of this so I could get past kernel panic and boot into installer
I'm using Big sir installer .
Dx79SR Intel Board DDR
Intel i7-3960X Extreme
Clover/Config
Clover/Config
See Patch AICPUM.
Hi, is there any updates or working method regarding ventura 13.3 and power management for x79 motherboard and 3930k cpu ?
ploukop
