Dell 3891
cyberlizard
Dell 3891
i5-10400
UHD 630
I recently managed to install Catalina (and then upgraded to Big Sur) on a pair of aging HP 800's (g1). I felt quite happy that I had achieved something, however, I also own a Dell 3891 with a 10th gen i5 processor and I am stuffed if I can get it to install.
Has anyone else had any success with the budget beast of a machine?
Steve aka cyberlizard
Yes, it's compatible.
do you have an EFI folder you can share as I have so far been thoroughly unsuccessful.
thanks.
mail @ cyberlizard . co . uk
thanks.
I know how to use the guide. I got two systems working using it. Guide or no guide I simply cannot get opencore even past the initial bootloader.
Attach your EFI to check.
Also, include your BIOS Settings.
the bios settings are default for the 3891
attached the EFI as a zip folder
educate me as I'm sure I haven't missed anything.
poriporto
