No, you need to prepare the configuration first. Moreover, you need to check whether your hardware is compatible or not.I preferer to go with catalina with a ready dmg file to install it via USB for a fresh install in a new empty disk. this is possible ??
Determining compatibility has to be done on the target machine. For creating configuration and preparing a bootable disk, you can do it on any system, whether Mac, Windows, Linux. It does not necessarily have to be the target computer.Thank you I started from youtube and it's not easy I will follow you guide. Just one question I need to follow this guide in the target machine or I can create the USB in my laptop for a desktop target machine ??
You should be able to flash it using 5v for the Gigabyte Card. Although, proceed at your own risk!Today I got the SPI flasher and the First step I need to verify with you if I need to downgrade the SPI flasher to 3.3v or I can use with the default 5v without damage the Gigabyte Card ??
Unfortunately, I have not documented "Patching Thunderbolt Security Level" yet. Although, the Internet is vast and you should be able to patch the firmware. Note that with the patched firmware (for macOS/OS X), the Thunderbolt will not work on Windows/Linux.And I will be back to you after getting the backup of all the ships Blue and Green with the default firmware and I will test the patched firmware's and try one by one and I hope if you have a Titan Ridge for windows with SL0 ready to flash.
Attach the Screenshots in English!Hi again my friends,
I took some time to flash the Titan Ridge 2 to version 50 with SL0 and now windows 11 recognize the card and show well the version of controller and the Firmware.
Now when I connect the Lacie thunderbolt device it's detected but windows have another problem and it's can't bridge and map the disk and I got an error 31 in device manager.
Any idea please to help me to solve the last step !!
