UHD 630 not working
WOW!
its work smoothly,
but one thing more, none of the GPUs are detected, this is problem?
i attached my completed EFI
WOW!
its work smoothly,
Seems like a userspace issue, more of a bug.
Make the following changes in your config.plist
- Disable AdviseFeatures in Platform>Generic section
- Enable SpoofVendor in Platform>Generic section
- Set SystemMemoryStatus to Auto in PlatformInfo>Generic section
- Remove ProcessorType in Platforminfo>Generic section
Delete all .plists files except com.apple.Boot.plist from Macintosh HD/Library/Preferences/SystemConfiguration
Restart, reset NVRAM twice, boot into macOS and provide the following
- IOReg
- kextcache output
- System Information (About This Mac>System Report>File>Save)
- Hackintool System Report
- Hackintool PCIe Report
the files, i didn't get the kextcache output, that what this showing
That's normal :)
Everything seems to be normal. Of course, USB ports are not mapped yet, but that's a separate issue. I would suggest you to perform a clean install. Monterey had IGPU issues since reease.
it's not that bad, everything works smoothly, it just seemed strange to me that there is supposedly no iGPU
thank you for the help, now I can have full macos experience!
GabyXB
