UHD 630 not working
con0 con1 con2...? that what you mean?
same problem, but thank you
i use display port, so i used con1
my new EFI
The config.plist is still not cleaned up properly.
Configure the following in your config.plist
- Disable the following Quirks from ACPI>Quirks section
  • FadtEnableReset
  • RebaseRegions
- Disable the following Quirks from Booter>Quirks section
  • EnableWriteUnprotector
- Enable the following Quirks from Booter>Quirks section
  • RebuildAppleMemoryMap
  • SetupVirtualMap
- Set Picker Attributes to 17 in Misc>Boot section
- Disable PollAppleHotKeys in Misc>Boot section
- Set Expose Sensitive Data to 6 in Misc>Security section
- Enable AllowNvramReset option in Misc>Security section
- Add -wegnoegpu as bootarg in NVRAM section
Save changes, restart, reset NVRAM twice, use onboard DP to boot into macOS. Reply with new complete set of PR files.
zainperdana
