UHD 630 not working
YosiCoco
msi z490a-pro
i7 10700k
intel UHD graphics \ GTX 1660 super
  2. Other
i'm installed olarila hackintosh monterey 12.5 raw image with default FEI on external drive, and this without gpu acceleration (in graphics memory it showing 8MB and in advanced this detected as NVIDIA gpu - my gpu is unsupported),
i tried enable iGPU and this don't worked (with disable nvidia gpu it don't load the hackintosh - efi work propely), i tried fix from videos and other forums
my hardware:
cpu - i7 10700k
metaboard - msi z490 pro-a
memory - 32 GB
external gpu - asus gtx 1660 super
external drive that I installed hackintosh - wd elements 2TB
sorry about my english, i'm not good
thanks.
my hardware:
cpu - i7 10700k
memory - 32 GB
thanks.
thanks for reply, but is dont recognise iGPU, it showing this in the kernel but no in the macos.
No PR files attached. Provide the following
- BIOS Settings (all pages, menus and sub-menus)
- EFI folder
- A copy of IOReg
here
Make sure you're using the onboard Display using HDMI/DP.
- Remove SSDT-OLARILA500.aml. You must remove the entry from ACPI section of your config.plist
- Add the following SSDTs
  • SSDT-AWAC-DISABLE
  • SSDT-EC-USBX
  • SSDT-PLUG
- Remove the following kexts. You must remove the entries from Kernel>Add section of your config.plist
  • AirportBrcmFixup
  • AirportItlwm
  • AppleMCEReporterDisabler
  • AtherosE2200Ethernet
  • CpuTscSync
  • IntelMausi
  • RealtekRTL8111
  • RestrictEvents
- Remove the following boot args
  • agdpmod=pikera
  • dk.e1000=0
  • e1000=0
- Cleanup your config.plist using the guide linked below
- Patch framebuffer using the guide linked below
"Make sure you're using the onboard Display using HDMI/DP."
if i connect on borard, the display don't reconise.
i do the other things later, thanks for the quick response
For IGPU to work, you must use the onboard Display. It is not working at the moment because you have not setup it correctly.
but i two problems
1. i have gpu acceleration but in mac igpu don't recognised (here screenshot)
2. to run a mac, I have to go into opencore with eGPU, select macos and transfer the DP to the board (if I run only when exiting the board, if the monitor shows me "DisplayPort No Signal")
This is because your Display is connected to NVIDIA instead of IGPU and probably, in headless mode
Framebuffer patching is required.
intellect98i
