Your mean Clover stock from github? I used Clover pkg 5148 from https://github.com/CloverHackyColor/CloverBootloader
Here's what you need to do.
Backup your existing Clover EFI
Delete your current EFI
Install Clover using the guide linked below
Make changes to your config.plist
Attach the EFI
Attach the EFI
I followed first your post , but same. I think if config.plist wrong, macos cant boot, right?
My problem: if load ApfsDriverLoader and HFS.efi from root usb via EFI Shell, mac can boot. But if put they in properly path Efi/clover/drivers, clover GUI even cant showup
You need to understand that you don't need to boot with that as you have already tried to boot and there is some issue. So, i need to check first and then outline what's wrong with that.
I create new EFI and same! Black Clover GUI. Dont think of any reason. Suck :(
Even in the early days of getting acquainted with hackintosh, I have not encountered a situation like this. Normally when I choose to boot into the mac partition, I will panic, bbut this case can't enter the Clover GUI interface even
Now, all you need to do is attach that EFI so that i can check for you :)
Reactions: oldman20
off course, plz
Well, you did not install the Clover as per the guide.
If you used the Clover installation guide, a Clover Install log file is created within the EFI directory which is missing in your case.
Here are the issues
- Remove the off directory from Clover/drivers directory
- ApfsDriverLoader.efi, AudioDxe.efi and SMCHelper.efi are missing.
- You're having multiple kext folders which are not recommended at all. A new guide for Clover is coming soon with everything updated. But it has been already discussed here
See "Placing required Kexts" section.
- You forgot to install a theme. The following guide recommends installing BGM theme, regardless of the UEFI or Legacy install.
- You're using PluginType=YES and also using SSDT-PLUG which is the wrong approach. Read here
- The Default Boot Volume and Legacy parameter is missing.
- Also, the recovery should be disabled using "NeverDoRecovery" option in Boot section.
- NVIDIA and ATI properties are still added which should be removed.
- Language and Screen Resolution is not set
- Inject ATI and Inject NVidia should be unchecked/disabled.
- DellSMBIOSPatch must be set to True to fix the truncating issue on Dell Systems.
Reactions: oldman20
if you had read all of Rehabman's guide you would know why they are set to enable
although you could use your own config.plist's for your guide, then there would be no issue
Looks like you're having outdated information. They're no longer required as a user can use the Device Properties method to disable the discrete GPU (either NVIDIA or AMD) using disable-external-gpu WEG's property. Secondly, the user can also use "-wegnoegpu" boot arg which is also a property of WEG.
Other solutions are to define an external declaration in an SSDT with the path of the actual GPU and it can also disable the GPU. The other way is traditional which requires DSDT+SSDT to disable the GPU.
Indeed!
alvarg82
