hey, I managed to install it, now I'm writing to you from there :D how do I know if everything is perfectly working? I saw that the video card is recognized correctly (RX580 +), the processor says "Unknown" I don't understand why ... the wifi I tried to use the Kext "itlwm" and it seems to work (for now I'm writing from Ventura :) what else should I check / install?
open core mount EFI. open config.plist with open core
Platform info
SMBIOS
put somthing like IMAC PRO 2017 OR NEWER. AND CHECK THE BOX
add this section in config.plist
Bloetooth working on Ventura....:)(y)
VENTURA BETA 2 UPDATE ...
I trying to install on my machine, but always stuck on welcome screen, did I miss something?
creating USB installer working fine, installed finish, but after that on Welcome Screen only mouse cursor I see nothing no Region/Languange dialog box.
after 5 or 10 menit then will reboot itself
*using iMac Pro 1,1 as SMBios
*GPU RX 6650 XT
*GPU RX 6650 XT
No PR files attached. Provide your EFI to check.
Reactions: kaizer_hanz
here my EFI (upload without DSDT)
this config plist I use on monterey without problem, all smooth.
- Remove Utilities folder
- No SSDT added
- Invalid Kexts
To fix the above issue, remove #INFO (prev-lang:kbd) from NVRAM and clear the value of prev-lang:kbd and you should see the installer.
- No SSDT added
- Invalid Kexts
Thanks let me try your suggestion, once again thanks
seph3421
