flopis27
- Jun 11, 2022
- aorus wifi pro
- i5 9600k
- amd 580
- 14.x
- iMac
- iMac Pro
open core mount EFI. open config.plist with open corehey, I managed to install it, now I'm writing to you from there how do I know if everything is perfectly working? I saw that the video card is recognized correctly (RX580 +), the processor says "Unknown" I don't understand why ... the wifi I tried to use the Kext "itlwm" and it seems to work (for now I'm writing from Ventura what else should I check / install?
Platform info
SMBIOS
put somthing like IMAC PRO 2017 OR NEWER. AND CHECK THE BOX
add this section in config.plist
