Provide your EFI and BIOS Settings to check further. Are you using OC from the commit 6c641b7?
To obtain the latest release, check the guide below
I've download commit e05a69d, it's the same thing? (I think it's the latest) or I need to download that version?
BIOS:
Integrated GPU - disabled
VT-d - disabled
Secure Boot -disabled
XHCIHandoff - disabled
Fastboot - Disabled
EFI:
- ACPI:
SSDT-AWAC.aml
SSDT-EC-USBX-DESKTOP.aml
SSDT-PLUG-DRTNIA.aml
- Driver:
HfsPlus.efi
OpenRuntime.efi
- Kext
AppleALC
Lilu
VirtualSMC
WhateverGreen
CONFIG:
-NVRAM
-v keepsyms=1 debug=0x100 alcid=7 -lilubetaall npci=0x2000
SMBIOS:
iMacPro1,1
do you need anything else?
EDIT: now stuck on:
"Couldn't alloc class "AppleKeyStoreTest"
"AppleFileSystemDriver: using boot-uuid
Reactions: flopis27
It's fine. Is latest. Shouldn't be an issue.
This must be enabled.
Use SSDT from OpenCorePkg
What are the Booter Quirks and Kernel Quirks?
Goood :D I re-enabled the Quirks "AvoidRuntimeDefrag" and boot but.....USB 3.0 not work :D I install "Legacy_USB3"?
Show me the Booter Quirks and Kernel Quirks.
Oh yes...upload pics :D
Enable AppleCpuPmCfgLock. Reset NVRAM and then try to boot the installer. Attach the verbose.
After 2 hours is full working...... only bluetooth problem i fixit leiter
where do i find OC v0.8.2 ?
guid to install
hey, I managed to install it, now I'm writing to you from there :D how do I know if everything is perfectly working? I saw that the video card is recognized correctly (RX580 +), the processor says "Unknown" I don't understand why ... the wifi I tried to use the Kext "itlwm" and it seems to work (for now I'm writing from Ventura :) what else should I check / install?
It shouldn't say Unknown Processor. Provide your PR files to check.
nicolacibin08
