NTFS-FS Error
ShaimGaming
Alienware Aurora R12 Motherboard
Intel Core i5 11400f
Gtx 750 Ti
So, I'm having an issue on the hackintosh. Theres my efi folder. It says voidAppleNVMeRequest timer and after that Ntfs-fs error (device /devdisk1s1 , pid 390): ntfs_restart_page_header_is_valid() then says panic dialog file unavailable, panic occurred prior to initialization. Can anybody help me solve this ntfs error? I need to get a hackintosh working before my mac gets sold.
Simply create an EFI according to this guide and you should be able to boot. Make sure your BIOS Settings are correct.
nnaa
