Acer Aspire 3 - i5 10210u - SSD not detected
I arrived late, but it does not matter I wanted to tell you that it is possible to install macOS on this pc I have an Acer Aspire A315-54 10th Gen , with macOS Montery 12.3.1 & Windows 10 installed in 2 SSD
To change the SATA MODE, you must enter the BIOS and type CTRL+S it will display a (Hidden) option to change it.
This information should help other people. :)
It can be fixed by using CtlnaAHCIPort.kext too.
Reactions: bahaedin
Is it possible without changing SATA MODE to AHCI ?
Because by default it is on Optane I think. :unsure:
Could be possible. Do you have Windows installed?
Boot to Windows. From Device Manager, Expand SATA/RAID Controllers.
Go to Properties, and then go to Details Tab. Select Hardware ID and provide a screenshot.
Now I am on AHCI I have already changed it from the BIOS
Just i want to know is it possible to install macOS with SATA MODE : Optane ?
Reactions: bahaedin
Try disabling wifi and bt kext in opencore .
xxxxxxxxxx
