Intel HD 4400 not working on Monterey
This isn't a "perfect EFI", maybe as per you only.
The following changes are needed.
- Remove first and second ACPI rename
- Remove ECEnabler.kext
- The sorting order for kexts are not correct. Use the guide to fix the sorting order
- Scan Policy should be set to 0
- AllowToggleSip will be set to false
- Add "-" before wegnoegpu boot arg
Nope now it is stuck (Photo pined)
Then it shows a error logo (photo pined)
Ill pin the EFI too.
EFI
No same error :(
EFI
Disable USB renames and WiFi/BT Kexts to check with. Make sure you're resetting NVRAM twice each time after implementing the changes. Also, are you booting into the installer?
It did boot but the SSD is again not showing up :(
EFI
EFI
Do you have Windows installed on this? Also, what's your exact Laptop model no.? Fix your profile.
Yes I have installed Windows and macOS BigSur dualbooted (Windows EFI partition is different).
Boot to Windows. From Device Manager, Expand SATA/RAID Controllers.
Go to Properties, and then go to Details Tab. Select Hardware ID and provide a screenshot.
What's your exact Laptop model no.?
incer01
