Intel HD 4400 not working on Monterey
Your configuration is not correct. For the current issue, the CtlnaAHCIPort.kext should be loaded after AppleALC, as your current config.plist. Also, make sure to reset NVRAM twice after the changes. In addition, are you sure if your drive is functional?
Nope its still not working :((
I am in windows so I don't know if I am doing it correct or not so could u plleasseee do it for me pleaseee. If not just say ill try to do it :(
EFI👆
EFI👆
You should consider starting from scratch.
I started from scratch and I made a EFI can u make sure everything is correctly done Pleasee?🥺
EFI👆
I started from scrach but my Macintosh HD disk in not showing in booter after installing macOS BigSur 11.6.5.(Installed macOS BigSur with another EFI which does not work in Monterey I am building a new EFI to get it work with monterey.)
Can u please share the list of elitebooks which can run macOS Monterey (I need it for a project at my office)so that I can install it perfectly :).
Please say if there is any problem with the EFI which I should fix.
EFI👆
EFI👆
The configuration is not correct. The following changes are needed.
- Use SSDT-EC instead of SSDT-EC-USBX.
- Use OpenHFSPlus.efi instead of HFSPlus.efi
- Remove all SMC kexts except for VirtualSMC. These are usually needed during postinstallation.
- Remove Thinkpad rename as your Laptop is not from Lenovo. In addition, remove the third rename.
- Rename B0D3 to HDAU (HDMI/DP Audio) is required for Broadwell, not Haswell.
- Enable UnblockFsConnect in UEFI section of your config.plist
- Remove outdated kexts and update with the latest ones.
The removal will be from config.plist and the directories as well.
The reason is cause your configuration is not correct. You must enable "UnblockFsConnect" in UEFI section of your config.plist.
No idea. You would need to open an EliteBook progress thread and discuss over there. You would need to provide specs to check the compatibility.
Reactions: Pranay
I did what u said and it did not boot so i created another EFI with proper as I installed BigSur it was easier to create so I created a perfect EFI but the same problem accord (SSD not showing).I don't know what to do and is there a list of supported HP laptops for monterey if there please pin.Ill pin the EFI please review for any errors.
EFI👆
EFI👆
This isn't a "perfect EFI", maybe as per you only.
- Remove first and second ACPI rename
- Remove ECEnabler.kext
- The sorting order for kexts are not correct. Use the guide to fix the sorting order
- Scan Policy should be set to 0
- AllowToggleSip will be set to false
- Add "-" before wegnoegpu boot arg
Where do I find ACPI rename?
alexito
