It has the RP05.PXSX address.
That's what I needed, changed the address from RP21 to RP05 in the SSDT and now Hot Plugging works! I just couldn't be sure of the address since it doesn't mention Thunderbolt in IORegistryExplorer.
Many Thanks!!
Well, it's normal for TB4. As there are no drivers for TB4 yet in Big Sur yet.
Many Thanks!!
Enjoy :)
Anyone else having problems upgrading to 12.3? While in 12.2.1 everything worked fine. After updating, it keeps shutting down within about a minute or two.
No PR files attached.
panic(cpu 0 caller 0xffffff801a9d38f3): Kernel trap at 0xffffff801a9173bd, type 13=general protection, registers:
CR0: 0x0000000080010033, CR2: 0x00007f8651812a00, CR3: 0x000000085553b02b, CR4: 0x00000000003626e0
RAX: 0x0000000000000000, RBX: 0x0100060830b2924f, RCX: 0x0000000000000001, RDX: 0xffffffd0c57cb1bc
RSP: 0xffffffd0c57cb140, RBP: 0xffffffd0c57cb180, RSI: 0xffffffd0c57cb1b0, RDI: 0xffffff8052ec9038
R8:  0xffffff8052ed1e60, R9:  0xffffff8052ed1de0, R10: 0x0000000000000402, R11: 0x0000000000000000
R12: 0xffffffd0c57cb1bc, R13: 0xffffffd0c57cb1b0, R14: 0xffffff9520276a90, R15: 0xffffff9520276a80
RFL: 0x0000000000010203, RIP: 0xffffff801a9173bd, CS:  0x0000000000000008, SS:  0x0000000000000010
Fault CR2: 0x00007f8651812a00, Error code: 0x0000000000000000, Fault CPU: 0x0, PL: 0, VF: 0
Panicked task 0xffffff8b85fe76d0: 3 threads: pid 96: diskarbitrationd
Backtrace (CPU 0), panicked thread: 0xffffff99eb75f000, Frame : Return Address
0xffffff801a70c070 : 0xffffff801a883e2d mach_kernel : _handle_debugger_trap + 0x41d
0xffffff801a70c0c0 : 0xffffff801a9e3cb6 mach_kernel : _kdp_i386_trap + 0x116
0xffffff801a70c100 : 0xffffff801a9d350d mach_kernel : _kernel_trap + 0x51d
0xffffff801a70c150 : 0xffffff801e8a2106 as.vit9696.VirtualSMC : __ZN18VirtualSMCProvider10kernelTrapI22x86_saved_state_1010_tEEvPT_Pm + 0x4b6
0xffffff801a70c1d0 : 0xffffff801a823a60 mach_kernel : _return_from_trap + 0xe0
0xffffff801a70c1f0 : 0xffffff801a8841fd mach_kernel : _DebuggerTrapWithState + 0xad
0xffffff801a70c310 : 0xffffff801a8839b6 mach_kernel : _panic_trap_to_debugger + 0x2b6
0xffffff801a70c370 : 0xffffff801b1164bf mach_kernel : _panic + 0x84
0xffffff801a70c460 : 0xffffff801a9d38f3 mach_kernel : _sync_iss_to_iks + 0x2c3
0xffffff801a70c5e0 : 0xffffff801a9d35e2 mach_kernel : _kernel_trap + 0x5f2
0xffffff801a70c630 : 0xffffff801e8a2106 as.vit9696.VirtualSMC : __ZN18VirtualSMCProvider10kernelTrapI22x86_saved_state_1010_tEEvPT_Pm + 0x4b6
0xffffff801a70c6b0 : 0xffffff801a823a60 mach_kernel : _return_from_trap + 0xe0
0xffffff801a70c6d0 : 0xffffff801a9173bd mach_kernel : _fill_procregioninfo_onlymappedvnodes + 0xcd
0xffffffd0c57cb180 : 0xffffff801aef2056 mach_kernel : _proc_piduniqidentifierinfo + 0xc66
0xffffffd0c57cb8a0 : 0xffffff801aeeea99 mach_kernel : _proc_info_internal + 0xe99
0xffffffd0c57cbee0 : 0xffffff801aeedc67 mach_kernel : _proc_info_internal + 0x67
0xffffffd0c57cbf10 : 0xffffff801aeedbef mach_kernel : _proc_info + 0x2f
0xffffffd0c57cbf40 : 0xffffff801af8ad2b mach_kernel : _unix_syscall64 + 0x1fb
0xffffffd0c57cbfa0 : 0xffffff801a824226 mach_kernel : _hndl_unix_scall64 + 0x16
      Kernel Extensions in backtrace:
         as.vit9696.VirtualSMC(1.2.9)[04E4F56A-32E7-3445-8894-07A2C59A8DF8]@0xffffff801e892000->0xffffff801e8b9fff
            dependency: as.vit9696.Lilu(1.6.0)[E5BEEE8E-E840-3224-BF88-B0A191D0F0A6]@0xffffff801e809000->0xffffff801e88ffff
            dependency: com.apple.iokit.IOACPIFamily(1.4)[CF250EA9-AE5C-3215-BCF5-763DB70A0228]@0xffffff801cf60000->0xffffff801cf61fff
Process name corresponding to current thread (0xffffff99eb75f000): diskarbitrationd
Boot args: -v alcid=11 agdpmod=pikera dk.e1000=0 keepsyms=1 debug=0x100 chunklist-security-epoch=0 -chunklist-no-rev2-dev chunklist-security-epoch=0 -chunklist-no-rev2-dev
Mac OS version:
21E258
Kernel version:
Darwin Kernel Version 21.4.0: Fri Mar 18 00:45:05 PDT 2022; root:xnu-8020.101.4~15/RELEASE_X86_64
Kernel UUID: B6F8637B-0844-355F-8C82-60FA06149384
KernelCache slide: 0x000000001a600000
KernelCache base:  0xffffff801a800000
Kernel slide:      0x000000001a610000
Kernel text base:  0xffffff801a810000
__HIB  text base: 0xffffff801a700000
System model name: iMacPro1,1 (Mac-7BA5B2D9E42DDD94)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 26022017117
Last Sleep:           absolute           base_tsc          base_nano
  Uptime  : 0x000000060f087b2d
  Sleep   : 0x0000000000000000 0x0000000000000000 0x0000000000000000
  Wake    : 0x0000000000000000 0x0000001d512124d5 0x0000000000000000
Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Zone info:
  Foreign : 0xffffff80215bd000 - 0xffffff80215cb000
  Native  : 0xffffff8052c94000 - 0xffffffa052c94000
  Readonly: 0xffffff851f960000 - 0xffffff86b92f9000
  Metadata: 0xffffffdd698b4000 - 0xffffffdd89bcb000
  Bitmaps : 0xffffffdd89bcb000 - 0xffffffdd95bcb000
Does that sound about right?
Problem Reporting Files
Mac OS version:
21E258
Kernel version:
Zone info:
Your kexts are outdated. Still, you haven't attached your PR files.
I will be getting a 10900k and Z590i UNIFY motherboard soon.
Question for @EliteMacx86
  1. can you share your scrubbed EFI? (my test Z590I wasn't working)
  2. does the 11th gen motherboard work with 10th gen iGPU? (HDMI, DP, and macOS intel iGPU features work)
  3. does thunderbolt work in macOS and Windows without any special configurations?
Thank you for your hard work!
Extra: I will be installing an nVidia GPU, which will be disabled in macOS and enabled in Windows. Do you recommend using OpenCanopy for boot slection, or a different tool for chossing OS at startup?
No, it's your responsibility to create one using the guides published here.
Yes, it does.
No, in that case, only on Windows. For Thunderbolt to work on Mac, you need to follow the guide published here.
Is there any reason not to? xD
Windows should be booted using its own Windows Boot Manager and macOS via the OC. That's the correct approach.
ilikeeatingpeeandpoo
