Evbarashka
 - Feb 23, 2022
 - ASUS X99 A-II
 - Xeon E5 2699 v3
 - Radeon RX560
 - iMac Pro
Your IOReg is corrupt. Use v2.1
Disable any Thunderbolt related SSDT and then attach a new IOReg.hm(((( dont open
Attch the PR files as described in post #1![]()
Looks like your post contradicts. You already mentioned that you have got it working, including HotPlug and USB Type-C. So, what do you mean by "it is possible other devices do not work correctly", do you test any other devices?I have only tested with my UA Apollo Twin X, so it is possible other devices do not work correctly.
Do you mean the BIOS Settings?Note that on this laptop, any time the system powers off unexpectedly (force power off or kernel panic), you will have to re-enter these settings.
Yes, this is referring to the BIOS settings.Do you mean the BIOS Settings?
