 - Feb 5, 2022
 - ASRock Z490 Phantom Gaming ITX/TB3
 - Intel I9-10850K
 - Sapphire RX 5500 XT 8GB
HI there,
First post but I frequently browse this forum,
I've built my current hack last summer and everything was working well (using UHD630) until I finally found a graphic card at a decent price and added it.
Since then my system randomly freezes and when it happens, I need to hard reboot it to be able to use it again, after the hard reboot no panic report is generated. Sometimes, it will reboot on its own and in this case when it reboots, I will first see the message that this Mac restarted due to a problem and can send the panic report to Apple (copy is attached).
I have also issues with sleep (turned off for the moment) where the system goes to sleep but when it wakes, the monitor does not turn on and the system reboots also generating a panic report.
I've been trying to find a solution for this but so far nothing I've tried worked and I have no issue with the card with Windows.
Attached are my EFI folder, a copy of IOReg and a copy of the last panic report I got after a reboot.
Hope someone can help
Thanks!
Thanks!
