GIGABYTE X299X Designare 10G - Intel Core i9-10980XE - 64GB RAM - AMD RX 5500XT - WiFi/BT - Thunderbolt 3 - OpenCore
GIGABYTE X299X Desginare 10G Guide featuring Intel Core i9-10980XE, Built-In Thunderbolt 3 and AMD RX 5500XT GPU using OpenCore. This guide can be used as a reference for any X299X Motherboard chipset with very few changes.
Components
GIGABYTE X299X Designare 10G Motherboard with Thunderbolt 3
Already Owned
Intel Core i9-10980XE 10th Gen Comet Lake Desktop Processor 12MB Cache 2.9 GHz
Corsair Vengeance RGB DDR4 3200MHz 64GB RAM (2x16GB) ()
ADATA - 250GB PCIe NVMe - M.2 Internal SSD (MZ-V6E250BW)
Fractal Design Define 7XL (CC-9011078-WW)
LG 32" Full HD IPS Monitor with HDMI, and Display Port (LG 22MP58VQ-P)
EVGA 600 BQ, 80+ BRONZE 600W Power Supply 110-BQ-0600-K1
Dell KM636 Wireless Keyboard & Mouse Combo
Comments
The Build
As the new 500 series Motherboard are out, with Thunderbolt 4 so i decided to test Thunderbolt 4. The idea of this build is to use Built-In Thunderbolt. The idea of this build is compact, paired with an i9 10900F running @ 2.9GHz stock speed, having a AMD RX 5700XT 8GB from Sapphire, good power supply with 600W, normal power consumption and a solid performance packed in ITX Build.
Already have a build with MSI Z490I UNIFY and same amount of PCIe slots were needed so the ultimate choice was Z590I UNIFY. It's an ITX motherboard offering support for 10th and 11th Gen. CPUs along with the Thunderbolt 4 support. The motherboard offers built-in Type-C Display. A solid audio codec (Realtek ALC4080), 2.5Gb/s LAN, PCIe 4.0 support for faster data transfer rate. Along with all these, the motherboard supports various features.
Summary
| Features | Status |
| Graphics | YES |
| Built-in Audio | YES |
| DP/HDMI | YES |
| DP/HDMI Audio | YES |
| Ethernet | YES |
| WiFi/BT | YES |
| AirDrop | YES |
| Handoff | YES |
| Thunderbolt 3 Hotplug | YES |
| Power Management | YES |
| App Store | YES |
| iMessage | YES |
| FaceTime | YES |
| iCloud | YES |
| USB 2.0, 3.0, 3.1 and USB Type-C Ports | YES |
Not working
Everything works like a charm.
Bootable Media Creation
2. Plug USB to your system.
4. Close Disk Utility.
5. Open Terminal and type:
| Directories | Description |
| Docs | Contains documentation, change log, a sample config.plist, and ACPI Samples for OpenCore. |
| IA32 | Contains OpenCore EFI, 32-bit OpenCore Boot Loader. |
| Utilities | Contains several utilities. |
| X64 | Contains OpenCore EFI, 64-bit OpenCore Boot Loader. |
Adding Required SSDTs
| SSDT Name | Notes |
| SSDT-AWAC |
| SSDT-EC-USBX |
| SSDT-PLUG |
Adding Required Drivers
| Driver Name | Required | Notes |
| OpenRuntime.efi | YES |
| OpenHfsPlus.efi | YES |
| OpenCanopy.efi | Optional |
| AudioDxe.efi | Optional |
3. From the EFI/OC directory, just keep the above drivers and delete rest of the drivers.
- All the drivers can be found at: X64/EFI/OC/Drivers
Adding Required Kexts
| Kext Name | Required | Notes |
| Lilu | YES |
| VirtualSMC | YES |
| WhateverGreen | YES |
| AppleALC | YES |
| NVMeFix | YES |
| USBInjectAll | YES |
| XHCI-unsupported.kext | YES |
| FakePCIID | YES |
| FakePCIID_Intel_I225-V | YES |
1. Download the above kexts.
Notes:
- Use the kext from RELEASE folder and RELEASE.zip file.
- Do not place unnecessary kexts here. It might prevent booting the installer.
- Only use basic kexts which is required to boot off the installer. You can install the rest required kexts at the time of post-installation.
- The VirtualSMC package includes Battery and Sensors plugins (SMCBatteryManager.kext, SMCDellSensors.kext, SMCLightSensor.kext, SMCProcessor.kext, and SMCSuperIO.kext). You do not need these kexts for booting the installer.
ACPI>Add
| SSDT Name | Notes |
| SSDT-AWAC |
| SSDT-EC-USBX |
| SSDT-PLUG |
ACPI>Patch
| Table Signature* | Find | Replace | Comment | Enabled | Notes |
| DSDT | 50454750 | 47465830 | Rename PEGP to GFX0 (Graphics) | YES |
| DSDT | 48454349 | 494D4549 | Rename HECI to IMEI (PAVP)* | YES |
| DSDT | 4D45495F | 494D4549 | Rename MEI to IMEI (PAVP)* | YES |
| DSDT | 48444153 | 48444546 | Rename HDAS to HDEF (Audio) | YES |
Booter>Quirks
| Quirks | Value | Notes |
| AvoidRunTimeDefrag | YES |
| DevirtualiseMmio | YES |
| EnableSafeModeSlide | YES |
| ProvideCustomSlide | YES |
| RebuildAppleMemoryMap | YES |
| SyncRuntimePermissions | YES |
| ProvideMaxSlide | 0 |
Note:
- The values which have been not discussed above, that will remain disabled.
DeviceProperties
This section is used for adding device properties. This includes PCI Devices information such as Graphics, Audio, WiFi, Ethernet and other controllers. The following changes are needed.
| Devices | Key | Value | Type | Notes |
| device-id |
| DATA |
Kernel>Add
| Arch | BundlePath* | ExecutablePath | PlistPath | Enabled | Notes |
| Any | Lilu.kext** | Contents/MacOS/Lilu | Contents/Info.plist | YES |
| Any | VirtualSMC.kext** | Contents/MacOS/VirtualSMC | Contents/Info.plist | YES |
| Any | WhateverGreen.kext** | Contents/MacOS/WhateverGreen | Contents/Info.plist | YES |
| Any | AppleALC.kext** | Contents/MacOS/AppleALC | Contents/Info.plist | YES |
| Any | USBInjectAll.kext | Contents/MacOS/USBInjectAll | Contents/Info.plist | YES |
| Any | XHCI-unsupported.kext | Contents/Info.plist | YES |
| Any | FakePCIID.kext | Contents/MacOS/FakePCIID | Contents/Info.plist | YES |
| Any | FakePCIID_Intel_I225-V.kext | Contents/Info.plist | YES |
Notes:
- All the plugins must load after loading it's dependencies otherwise the kext will no longer function even when loaded in OS X/macOS.
- The mandatory kexts must be loaded in sorted order as shown in the above table.
- *Indicates BundlePath i.e. Name of the Kext
- **Indicates mandatory kexts.
- All the added kexts must exists in the EFI/OC/Kexts directory.
- The options which have been not discussed above, that will remain untouched.
Kernel>Scheme
| Options | Value | Notes |
| FuzzyMatch | YES |
| KernelArch | Auto |
| KernelCache | Auto |
Kernel>Quirks
| AppleCpuPmCfgLock | YES |
| AppleXcpmCfgLock | YES |
| DisableIoMapper | YES |
| PanicKNoextDump | YES |
| PowerTimeoutKernelPanic | YES |
| XhciPortLimit | YES |
| DisableRtcChecksum | NO |
| DisableLinkeditJettison | YES |
Note:
NVRAM>Add
| UUID | Key | Value | Type | Notes |
| 7C436110-AB2A-4BBB-A880-FE41995C9F82 | boot-args |
| STRING |
| csr-active-config |
| DATA |
| prev-lang:kbd | en-US:0 | STRING |
PlatformInfo
Suggested SMBIOS
| SMBIOS | CPU |
| iMac 20,1 | Intel Comet Lake for i3 and i7 |
| iMac 20,2 | Intel Comet Lake for i9 |
DataHub
| Option | Value | Notes |
| Add this section in config.plist | YES | Adds DataHub field |
Generic
| Add this section in config.plist | YES | Adds Generic field |
| from SMBIOS | YES | |
| ProcessorType | 0 |
| SystemMemoryStatus | Auto |
| SpoofVendor | YES | Sets SMBIOS vendor fields to Acidanthera |
PlatformNVRAM
| Option | Value | Note |
| Add this section in config.plist | YES | Adds PlatformNVRAM field |
For more information on Comet Lake config.plist, check the post linked below.
GUIDE - How to Create OpenCore Config.plist file for booting macOS on Intel Desktops
How to Create OpenCore Config.plist file for booting macOS on Intel Desktops An EliteMacx86 Exclusive Guide - This guide covers creation of config.plist for booting macOS on Intel Desktops for OpenCore as a bootloader. Overview The config.plist is a system configuration file for the...
elitemacx86.com
SMBIOS
| Add this section in config.plist | YES | Add SMBIOS field. |
Installing OpenCore EFI
2. Copy the EFI from your working directory to EFI partition of your Bootable USB Flash Drive.
Now you’ve successfully installed OpenCore, the required drivers, kexts and config.plist and the USB Flash drive is ready to boot off your computer.
UEFI Settings
- Set Optimized Defaults.
- Set X.M.P. Memory Profile to Profile 1.
- Set Fast Boot to Disabled.
- Set Windows 8/10 Features to Other OS.
- Set Initial Display Output to IGFX.
- Set Intel Platform Trust Technology (PTT) to Disabled.
- Set Network Stack to Disabled.
- Set XHCI Hand-Off to Enabled.
- Set SATA Mode to AHCI.
- Set VT-d option to Disabled.
- Set Internal Graphics to Auto.
- Save & Exit Setup.
Installation
Turn on your system.
6. Repeat step no. 5.
| Name | Macintosh HD |
| Format | APFS |
| Scheme | GUID Partition Map |
12. Close Disk Utility.
This will take couple of minutes and will restart at "Less than a minute is remaining". Upon completion, the system will automatically restart. The System will restart to complete the installation. Here it ends the first phase of the installation.
Post Installation
Now, configuring the Post Installation. There is not much to do for the postinstallation except configuring Thunderbolt 3 Hotplug and the boot from system drive. Everything rest is fully functional.
To activate Thunderbolt 3, follow the steps from the guide linked below.
GUIDE - How to Enable Thunderbolt 3 Hotplug on macOS
How to Enable Thunderbolt 3 Hotplug on macOS [Clover/OpenCore] An EliteMacx86 Exclusive Guide - This guide covers the implementation of Thunderbolt™ 3 Hotplug on macOS for single and multiple Thunderbolt 3 Cards. Overview An EliteMacx86 Exclusive Guide - In our previous post, we covered a...
www.elitemacx86.com
Boot from System Drive
3. Open your EFI Partition of your Hard Drive.
6. Copy the EFI folder from your macOS Bootable USB to your EFI Partition of your Hard Drive.
By using this method, you’ll be easily able to install OpenCore Boot loader on your System Drive.
