How to Patch Laptop DSDT and SSDTs
This guide covers patching Laptop DSDT and SSDTs for macOS/OS X. By following this guide, you'll be able to patch your OEM DSDT/SSDTs.
I. Overview
To enable macOS features and various hardware and maintain stability, DSDT and SSDTs patching are required. Patching the DSDT and SSDTs makes the perfect functioning of the laptop and also avoids issues and conflicts with the hardware.
Before you start the process, here are some notes.
Using DSDT and SSDTs from another system is relatively easy than patching yours but will not result in any benefit as each hardware is unique, even if it's from the same manufacturer. Every laptop has different ACPI tables which might not match your laptop and the results may not be as expected. Sometimes you might even fail to boot or have a few restarts/panics or crashes. The hardware would not be stable and can cause errors with functions. The effect could be adverse like issues with Audio plugins for DAWs. Such practice is dangerous and highly discouraged.
Even if you tend to use the same model from the same manufacturer, the tables may be different than yours. The reason is that the other laptop may have a different BIOS/firmware version than yours, different RAM size, BIOS/firmware options configured, and WiFi hardware can make a difference resulting in unstable hardware and other bugs. In addition, such differences can make various OperationRegion addresses different, resulting in incompatible with one another. Also, the same laptop can have a different motherboard, hence incompatible ACPI files when used for another laptop. So it's better to patch your specific DSDT and SSDTs.
You need to re-extract and re-patch your DSDT and SSDTs if any of the following events take place.
The patching involves 6 different steps which include:
II. Extracting ACPI Files
The very first step is to extract the native ACPI files. The native ACPI files can be extracted using Clover Bootloader, macOS, Linux, or even Windows. This guide will focus on three methods of extraction: But the only recommended method is using the Clover Bootloader.
Method #1: Using Clover
Extracting the native ACPI files using the Clover method (F4) is recommended due to the ease of extraction, and due to the ease of comparison between ACPI/origin and ACPI/patched directory (for troubleshooting) and avoiding any further errors and corruption. Follow the steps below to extract your native ACPI files using Clover.
1. To begin with the process of extraction, you need to have Clover Bootloader installed. If you're using OpenCore as your primary bootloader, you'll need to install Clover Bootloader to your ESP or the USB Flash Drive.
2. Load Optimized Defaults and then apply necessary changes in your BIOS/firmware before extracting the native ACPI files. See BIOS Settings for macOS for more information.
3. On your target system, boot to the Boot menu.
4. Boot using your USB or the System Drive.
5. When at Clover picker, press
6. After extracting the ACPI files, boot back to macOS/OS X and verify the ACPI files. If you're unable to boot the target system, you can still use the Bootable USB on any other system containing the dumped ACPI files. The dumped/extracted ACPI files are located/saved under
The Clover will extract all the native ACPI files in the EFI/Clover/origin directory. If you're using any "Clover Fixes" (hotpatch), Clover will dump one additional ACPI file with the name DSDT-XXXXXXXX. Where, the XXXXXXXX are the random characters. This DSDT will include the Clover fixes and therefore, you must exclude such DSDT when disassembling the ACPI files. However, extracting the ACPI files without the "Clover Fixes" is a much safer approach.
Method #2: Using Linux
If you're familiar with Linux, the native ACPI files can be extracted directly from the File System. To extract using Linux, follow the steps below.
1. Boot into Linux (if already installed). Note that it is not necessary to install Linux. If you do not have Linux installed on the target system, you can create a Linux USB and can boot into Linux Live.
2. In Linux, the ACPI files can be found at
3. Create a directory on your Desktop and copy all the ACPI files from the above directory.
Method #3: Using AcpiDump
Method #4: Using Patchmatic
Provided that you're not booting with any patched ACPI files, you can extract the native ACPI files using patchmatic. Note that this method requires macOS/OS X to be installed on the target system. However, this method is not recommended. To extract using patchmatic, follow the steps below.
1. Download patchmatic.
2. Create a working directory on your Desktop. You can use any name of your choice. For ease of this guide, we'll be using the name ACPI.
3. Extract patchmatic and copy the patchmatic to the directory you created above.
4. Open the Terminal and execute the following commands.
5. Once extracted, quit Terminal.
The patchmatic will extract all the loaded ACPI files in the ACPI directory. If you're using any patch which affects the DSDT/SSDTs, you'll not be able to get native ACPI files. For example, dropping any ACPI tables using
Method #4: Using SSDTTime
III. Disassembly
The next step is to disassemble the extracted files. Follow the steps below to disassemble your native ACPI files. Depending on the OS your computer has, choose one of the appropriate methods to disassemble your native ACPI files.
For macOS users
For users with macOS computers, there are two methods available which are described below. Depending on your preferences, choose one of the methods described below. For users with macOS computers, we recommend Offline Method for creating the Bootable USB.
I. Preparing iasl compiler
Before you start disassembling the ACPI files, you need to prepare iasl compiler, which is run from the Terminal. To disassemble the extracted files, you'll need the iasl compiler. Follow the steps below to download and copy the iasl compiler. Depending on your Laptop type, select one from below
Depending on the branch you choose, download the latest version. The latest version is recommended to avoid any errors during disassembly.
(a). Rehabman Branch
If you're using Rehbaman Branch, follow the steps below to obtain iasl compiler.
1. Visit the Rehabman acpica downloads
2. Download iasl from top.
3. Extract the downloaded .zip file
4. Once extracted, you'll get the iasl compiler from the zip.
(b). ACPICA Branch
If you're using ACPICA Branch, follow the steps below to obtain iasl compiler.
1. Visit the ACPICA downloads
2. From the Downloads section, select UNIX Source Code.
3. Download
4. Extract the downloaded .tar.gz file to your Desktop.
5. Open the Terminal and execute the following commands
You can also build the iasl using the command below
You'll find the iasl compiler in
II. Copying iasl compiler
The next step is to copy the compiler to the working directory so that it can be easily accessed.
1. Create a working directory on your Desktop. Use the name of your choice. For ease of this guide, we'll be using the name
For Rehabman Branch
Copy the
For ACPICA Branch
Copy the
III. Disassembling ACPI Files
The next step is to disassemble the ACPI files. The extracted files can be opened using MaciASL but it is not recommended. As if the AML has complex references to other AMLs, it will not disassemble correctly and when compiling, it will be left with many errors. Some of those errors can be fixed and some might be difficult enough to fix due to poor disassembly. So it's recommended that you disassemble your native ACPI files properly. To disassemble the extracted ACPI files, follow the steps below.
1. Copy all the native
2. Make sure all the files are present as original when extracted. The extracted files will have a
3. Create a
The following refs.txt content has some common (and not so common) missing symbols that the disassembler tends to be confused by.
Refs:
This will create a
5. Assuming the Terminal is still open, execute one of the following commands in Terminal
Using Refs.txt:
New Laptops don't need
Also, note that for newer ACPI sets, (usually, Skylake and later) there is no need for
You'll see something similar to the following as an output of the operation:
This will disassemble all of your extracted ACI files (DSDT and SSDTs) in the origin directory and from this point onwards, you will work with the
Disassembly Errors
Duplicate ACPI Files
Sometimes, Clover writes duplicate SSDTs. These duplicate SSDTs can cause problems during disassembly. If you have duplicate definitions issues during disassembly, you'll need to analyze all the SSDTs to eliminate the files which are duplicated. To find out the duplicate files, you can check the file size. Files with equal size are likely duplicates. However, checking the content is highly recommended.
To check the file sizes in bytes of all SSDTs, follow the steps below.
1. Open the Terminal and execute the following commands.
If you have files of the same size, delete them and re-disassemble the files and you should have the disassembly successful. Note that you must delete the existing disassembled files before the re-disassembly.
Could not parse external ACPI tables, AE_ALREADY_EXISTS
Another common issue during disassembly is
iASL: Segmentation Fault; iASL: Terminating
IV. Analyzing Native ACPI Files
Once you're done with the disassembly, you may want to look at the content of each
Except for patching to disable the discrete graphics device and map the brightness hotkeys (rare case), it is really not necessary to patch any SSDTs which are accompanied during the ACPI extraction process as the common renames can be done via the config.plist (Clover or OpenCore) and is the recommended method instead of patching the DSDT with renames. Although, both methods will have the same effect. Note that with the recent progress of Lilu, WhateverGreen, and other related kexts, the renames are done on the fly and for most of the cases, you don't need to rename via config.plist.
For the most part, the main focus is the DSDT. However, SSDTs have their own importance as well.
V. Fixing Errors
After the disassembly, the disassembled native ACPI files can still have errors even when disassembling all ACPI files at once and with the
Most of these errors can be fixed using RehabMan patches for the Laptops. The patches for syntax/error problems begin with
Other errors can be fixed by removing/uncommenting the lines causing the error. However, it depends on whether the line is necessary for the proper operation of the code or not. For example, errors caused by
External Declratations
It is very common to have extraneous/unnecessary External declarations. For example a recent DSDT I looked at had quite a few "Name already exists in scope" errors. For DTSE, DTS1, DTS2, DTS4, BNUM, PDTS, PKGA, SPST.
The fix is to simply comment out the related External declarations.
Another common error with some Dell DSDT files is due to the
Replace this code:
with this one :
Invalid leading asterisk (*pnpxxxx)
Another common error in the DSDT is "Invalid leading asterisk (*pnpXXXXX)". Where the X represents the HID name. You can apply
Name already exists in scope (__DSM)
Another common error in the DSDT is "Name already exists in scope (DSM)". You can apply
syntax error, unexpected PARSEOP_PACKAGE
Another common error in the SSDT is
Invalid type (Target is [Package], Source must be a package also)
Warnings/Remarks/Optimizations
During compiling the ACPI files, you might have noticed that there are several warnings, remarks, and optimizations. However, warnings, remarks, and optimizations don't matter but errors do. You cannot save the particular DSDT or SSDT file until you have all errors resolved. Therefore, you must fix all the errors before you can save the ACPI file as
VI. Patching the DSDT and SSDTs
After fixing the disassembled files, (error free), the next step is to patch the DSDT. Once you disassemble the native files, create a folder and place all the disassembled DSDTs and SSDTs in this new directory.
Before you start patching your DSDT/SSDTs, it would be good if you compile the disassembled files and look for the errors, if any. This is because when you apply some patches, they might not be suitable for your DSDT/SSDTs and it can cause errors when compiling. So determining whether the specific patches are causing the errors or the native disassembled DSDT/SSDTs themselves, can be difficult. Once you compile the disassembled files, and if there's no error, you can continue to apply the patches.
Download MaciASL
Copy MaciASL
1. Download the MaciASL of your choice.
2. Extract the MaciASL and move it to the Applications folder.
There are some common patches for the DSDT and SSDTs which needs to be applied. The common patches are listed below.
Common Patches (DSDT)
Common Patches (SSDTs)
Problem Specific Patching
Backlight Hotkeys
Battery Status
Backlight Control
Disabling Discrete Graphics
VoodooI2C
ASUS SMC
Applying the Patches
To apply the patch, follow the steps below.
1. Open your disassembled DSDT or SSDT using MaciASL.
2. Click on the Patch button and you'll several patches available to apply in the left pane.
3. Find and select the patch from the left pane and click on Apply. For example, we would be applying the IRQ Fix.
4. Once the patch is applied successfully, you'll see something like below.
5. Click on Close and you'll see something like below.
VII. Compiling
After patching the DSDT and SSDTs, you need to compile the files.
Simply click on compile and look for errors in the Compiler Summary. If there's an error, fix it and again click on Compile.
If there's no error, the files will be compiled successfully.
VIII. Saving the ACPI files
After compiling, the next step is to save the file to be loaded by the bootloader.
1. Go to File
2. Select Save as
3. A dialogue box will appear asking for the location and the file format to save the file.
4. Select a new location.
5. Select
6. Click on Save.
IX. Installing the DSDT and SSDT
After finishing all the steps, you need to install the DSDT and SSDT.
1. Copy all the patched DSDT and SSDTs
2. Mount your EFI partition
For Clover:
If you're using Clover, copy all patched DSDT and SSDTs to
For OpenCore:
If you're using OpenCore, copy patched DSDT and SSDTs to
Recommended configurations for using DSDT and SSDTs
The following configurations are the only valid configurations. Anything else is likely wrong and should not be used. We prefer the full patched DSDT+SSDTs
Full patched DSDT + SSDTs:
- Patched DSDT.aml in ACPI/patched (Clover) or in ACPI (OpenCore).
- Full set of patched OEM SSDTs in ACPI/patched (Clover) or in ACPI (OpenCore). (SSDTs names must be the same as in ACPI/origin)
- Add-on SSDTs also placed in ACPI/patched (Clover) or in ACPI (OpenCore).
- SortedOrder required to set SSDT load order(SSDTs order must be same as in ACPI/origin)
- DropOem=True
Partial Hotpatch:
- Only add-on SSDTs in ACPI/patched (Clover) or in ACPI (OpenCore) (eg. no patched SSDTs)
- SortedOrder left unspecified
- DropOem=False
Extra Information
Credits:
I. Overview
- BIOS/Firmware Update
- Changing Memory size
- Changing BIOS/firmware options
- Changing any other hardware (such as WiFi)
- Extracting ACPI files
- Disassembly
- Patching
- Compiling
- Saving
- Installing
F4
to extract the native ACPI files. It will take some time, typically a few seconds to extract the files.6. After extracting the ACPI files, boot back to macOS/OS X and verify the ACPI files. If you're unable to boot the target system, you can still use the Bootable USB on any other system containing the dumped ACPI files. The dumped/extracted ACPI files are located/saved under
EFI/Clover/ACPI/origin
directory. If the files are present in the directory, it means the extraction is successful.NOTES:
- The BIOS must be set before extracting the ACPI files. See Setting up BIOS for booting macOS/OS X for more information.
- To extract the native ACPI files, it is not required to configure the config.plist as per your hardware. Only Clover installation is necessary for extracting the ACPI files.
- A folder with the name
origin
must exist in theEFI/Clover/ACPI/origin
directory. Automatically created when installing Clover bootloader.- Some laptops use the Fn+Fx function so when in doubt, press both Fn+F4 and F4. Never press F4 or Fn+F4 twice to prevent duplicate or incomplete extraction.
- There's no progress on the screen during extraction or after the dump, just a slight delay as the files are written onto the ESP or the USB. The delay is more noticeable if the ACPI files are being written to USB (in case booting the Clover off the USB Flash Drive). It might feel stuck/hung but at that time, the Clover dumps/writes the files to your USB or the system drive.
- The extracted files are the native/unpatched ACPI files. You'll need to patch these.
/sys/firmware/acpi/tables
and /sys/firmware/acpi/tables/dynamic
.3. Create a directory on your Desktop and copy all the ACPI files from the above directory.
Bash:
#Move to the directory
cd Desktop/ACPI
#Extract using patchmatic
/Users/yourusername/Desktop/ACPI/patchmatic -extract
DropSSDT=Yes
(Chameleon) or DropOem=True
(Clover) or ACPI>Delete
(OpenCore), the native SSDTs will be dropped before macOS/OS X can load them and it will be missed in the patchmatic extraction. The same applies if you're using Clover's DSDT Fixes
or ACPI Renames
as these are directly patching the native DSDT and to do your own patching, you definitely don't want that. Any addon SSDTs or Hotpatch will inject extra SSDTs which can cause complications during the disassembly. Due to all such complexity involved, this method is not recommended and Clover F4 is much more preferred option.Method #4: Using SSDTTime
III. Disassembly
For macOS users
Branch | Notes |
Rehabman |
ACPICA |
(b). ACPICA Branch
3. Download
UNIX Format Source Code and Build Environment with Intel license
.4. Extract the downloaded .tar.gz file to your Desktop.
Bash:
cd Desktop/acpica-unix-VERSION
#Build iasl compiler
make clean
make iasl
CFLAGS="-mmacosx-version-min=10.7 -O3" \
LDFLAGS="-mmacosx-version-min=10.7" \
make iasl -j $(getconf _NPROCESSORS_ONLN)
generate/unix/bin/iasl
directory.QUICK NOTE:
- Replace the VERSION with the actual acpica version. For example, 20220331.
origin
.For Rehabman Branch
Copy the
iasl
from the Downloads
directory to the origin
directory.For ACPICA Branch
Copy the
iasl
from Desktop/acpica-unix-VERSION/generate/unix/bin
directory.III. Disassembling ACPI Files
DSDT
and SSDT
files to the origin
directory on the Desktop. Do not copy ACPI files that don't begin with DSDT or SSDT.2. Make sure all the files are present as original when extracted. The extracted files will have a
*.aml
extension. If not, rename the files to .aml
extension.3. Create a
refs.txt
file where you've placed the DSDT and SSDTs. The advantage of using the refs.txt
when disassembling the files is, that it can eliminate several common errors while disassembly resulting in saving time to fix the common errors. Sometimes there are additional unresolved externals (symbols not defined in any file). The iasl disassembler will attempt to guess the number of arguments, but often it guesses poorly. You can correct it, by providing the External declarations in a text file. Some common unresolved symbols are SGPO, ECRD, ECWT, and MMTB.The following refs.txt content has some common (and not so common) missing symbols that the disassembler tends to be confused by.
Refs:
External(MDBG, MethodObj, 1)
External(_GPE.MMTB, MethodObj, 0)
External(_SB.PCI0.LPCB.H_EC.ECWT, MethodObj, 2)
External(_SB.PCI0.LPCB.H_EC.ECRD, MethodObj, 1)
External(_SB.PCI0.LPCB.H_EC.ECMD, MethodObj, 1)
External(_SB.PCI0.PEG0.PEGP.SGPO, MethodObj, 2)
External(_SB.PCI0.GFX0.DD02._BCM, MethodObj, 1)
External(_SB.PCI0.SAT0.SDSM, MethodObj, 4)
External(_GPE.VHOV, MethodObj, 3)
External(_SB.PCI0.XHC.RHUB.TPLD, MethodObj, 2)
Bash:
cd Desktop/origin
#Copy the above refs text
#Paste copied text to refs.txt
pbpaste>refs.txt
This will create a
refs.txt
file in your current working directory.5. Assuming the Terminal is still open, execute one of the following commands in Terminal
Using Refs.txt:
Bash:
/Users/yourusername/Desktop/origin/iasl -da -dl -fe refs.txt DSDT.aml SSDT*.aml
refs.txt
and the following disassembly command should be used:
Bash:
/Users/yourusername/Desktop/origin/iasl -da -dl DSDT.aml SSDT*.aml
-da
and refs.txt
as they have external opcodes and can conflict with the embedded External opcodes. The following disassembly command should be used in such cases:
Bash:
/Users/yourusername/Desktop/origin/iasl -dl DSDT.aml SSDT*.aml
Intel ACPI Component Architecture
ASL+ Optimizing Compiler/Disassembler version 20180427(RM)
Copyright (c) 2000 - 2018 Intel Corporation
Input file DSDT.aml, Length 0xD8E0 (55520) bytes
ACPI: DSDT 0x0000000000000000 00D8E0 (v02 HP INSYDE 00000001 MSFT 01000013)
External object resolution file SSDT-x0_3-ApCst.aml
Input file SSDT-x0_3-ApCst.aml, Length 0x119 (281) bytes
ACPI: SSDT 0x0000000000000000 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
Pass 1 parse of [SSDT]
Pass 2 parse of [SSDT]
External object resolution file SSDT-x0_2-Cpu0Cst.aml
Input file SSDT-x0_2-Cpu0Cst.aml, Length 0x891 (2193) bytes
ACPI: SSDT 0x0000000000000000 000891 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
External object resolution file SSDT-x0_1-ApIst.aml
Input file SSDT-x0_1-ApIst.aml, Length 0x303 (771) bytes
ACPI: SSDT 0x0000000000000000 000303 (v01 PmRef ApIst 00003000 INTL 20051117)
External object resolution file SSDT-x0_0-Cpu0Ist.aml
Input file SSDT-x0_0-Cpu0Ist.aml, Length 0x432 (1074) bytes
ACPI: SSDT 0x0000000000000000 000432 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
External object resolution file SSDT-0-CpuPm.aml
Input file SSDT-0-CpuPm.aml, Length 0x9F1 (2545) bytes
ACPI: SSDT 0x0000000000000000 0009F1 (v01 PmRef CpuPm 00003000 INTL 20051117)
refs.txt: Importing method external (1 arguments) MDBG
refs.txt: Importing method external (0 arguments) _GPE.MMTB
refs.txt: Importing method external (2 arguments) _SB.PCI0.LPCB.H_EC.ECWT
refs.txt: Importing method external (1 arguments) _SB.PCI0.LPCB.H_EC.ECRD
refs.txt: Importing method external (1 arguments) _SB.PCI0.LPCB.H_EC.ECMD
refs.txt: Importing method external (2 arguments) _SB.PCI0.PEG0.PEGP.SGPO
refs.txt: Importing method external (1 arguments) _SB.PCI0.GFX0.DD02._BCM
refs.txt: Importing method external (4 arguments) _SB.PCI0.SAT0.SDSM
refs.txt: Importing method external (3 arguments) _GPE.VHOV
refs.txt: Importing method external (2 arguments) _SB.PCI0.XHC.RHUB.TPLD
refs.txt: Imported 10 external method definitions
Pass 1 parse of [DSDT]
Pass 2 parse of [DSDT]
Parsing Deferred Opcodes (Methods/Buffers/Packages/Regions)
Parsing completed
Found 17 external control methods, reparsing with new information
Parsing completed
Warning - Emitting ASL code "External (_SB_.PCI0.GFX0.DD02._BCM)"
This is a conflicting declaration with some other declaration within the ASL code.
This external declaration may need to be deleted in order to recompile the dsl file.
Disassembly completed
ASL Output: DSDT.dsl - 428844 bytes
iASL Warning: There were 17 external control methods found during
disassembly, but only 10 were resolved (7 unresolved). Additional
ACPI tables may be required to properly disassemble the code. This
resulting disassembler output file may not compile because the
disassembler did not know how many arguments to assign to the
unresolved methods. Note: SSDTs can be dynamically loaded at
runtime and may or may not be available via the host OS.
In addition, the -fe option can be used to specify a file containing
control method external declarations with the associated method
argument counts. Each line of the file must be of the form:
External (<method pathname>, MethodObj, <argument count>)
Invocation:
iasl -fe refs.txt -d dsdt.aml
External object resolution file DSDT.aml
ACPI Error: AE_ERROR, [/_SB_PCI0GFX0DD02_BCM] has conflicting declarations (20180427/dmextern-1148)
Parsing completed
Found 10 external control methods, reparsing with new information
Parsing completed
ASL Output: SSDT-0-CpuPm.dsl - 14753 bytes
Parsing completed
Parsing completed
ASL Output: SSDT-x0_0-Cpu0Ist.dsl - 9925 bytes
Parsing completed
Found 12 external control methods, reparsing with new information
Parsing completed
ASL Output: SSDT-x0_1-ApIst.dsl - 6017 bytes
Parsing completed
Parsing completed
ASL Output: SSDT-x0_2-Cpu0Cst.dsl - 43831 bytes
Parsing completed
Found 11 external control methods, reparsing with new information
Parsing completed
ASL Output: SSDT-x0_3-ApCst.dsl - 2928 bytes
.dsl
files exclusively using MaciASL. Although to use those DSDT and SSDTs, they must be saved as ACPI Machine Language Binary
with an .aml
extension. However, it is always recommended to keep the original and patched .dsl
files in case you need to apply more patches in the future.Disassembly Errors
Bash:
cd Desktop/origin
#List file size
ls -l SSDT*.aml
-rwxrwxrwx 1 elitemacx86 staff 2545 Nov 8 20:51 SSDT-0-CpuPm.aml
-rwxrwxrwx@ 1 elitemacx86 staff 1074 Nov 8 20:51 SSDT-x0_0-Cpu0Ist.aml
-rwxrwxrwx 1 elitemacx86 staff 771 Nov 8 20:51 SSDT-x0_1-ApIst.aml
-rwxrwxrwx 1 elitemacx86 staff 2193 Nov 8 20:51 SSDT-x0_2-Cpu0Cst.aml
-rwxrwxrwx 1 elitemacx86 staff 281 Nov 8 20:51 SSDT-x0_3-ApCst.aml
. This error is mainly caused due to duplicate ACPI files and when the files are disassembled incorrectly. For example, disassembling ACPI files from a Comet Lake using the refs option (iasl -da -dl -fe refs.txt DSDT.aml SSDT*.aml) or the option (iasl -da -dl DSDT.aml SSDT*.aml) will give such error. You must disassemble the files correctly.iASL: Segmentation Fault; iASL: Terminating
iASL: Segmentation Fault iASL: Terminating
. When you have this error, the disassembly will not be completed and you must fix the issue to disassemble the ACPI files. This error is mainly caused when disassembling the ACPI files using Refs.txt, where it is not required. Typically, SKL and newer.NOTES:
- Whenever you start the disassembly, make sure that you disassemble all the files at a time.
- Do not disassemble other ACPI files other than the ACPI files starting with the DSDT and SSDT names.
- Do not disassemble specific files only. It will be prone to error.
- The disassembled files will have a
.dsl
extension.- If you directly open the
.aml
files using MaciASL and then click on compile button then you're doing it wrong. Doing so will not only cause errors when compiling but also you would waste time in fixing the common errors due to poor disassembly.- Sometimes you might get errors while disassembling the native files. The reason is due to the duplicate SSDTs. If there are any such errors, find the duplicated SSDT and remove it and then disassemble it.
- You must replace "yourusername" with your actual username.
.dsl
file to familiarize yourself with the contents of each disassembled file. Certain patches are dependent on the content and in some cases, you might need to add/remove or modify the content to apply the patch. For example, if you're patching the DSDT to disable the discrete graphics, you may be looking for the _OFF method as it relates to that device. However, disabling the discrete graphics is covered in a separate guide and has been also linked later in this guide.Except for patching to disable the discrete graphics device and map the brightness hotkeys (rare case), it is really not necessary to patch any SSDTs which are accompanied during the ACPI extraction process as the common renames can be done via the config.plist (Clover or OpenCore) and is the recommended method instead of patching the DSDT with renames. Although, both methods will have the same effect. Note that with the recent progress of Lilu, WhateverGreen, and other related kexts, the renames are done on the fly and for most of the cases, you don't need to rename via config.plist.
V. Fixing Errors
refs.txt
method. The disassembled files can have errors due to several underlying factors such as changes in iasl, bugs in iasl itself, and the differences in the compilation environments between our laptops and the OEM. These errors must be fixed otherwise the files will not be compiled and saved further.Most of these errors can be fixed using RehabMan patches for the Laptops. The patches for syntax/error problems begin with
[syn]
in the patches. You can use it to fix common errors. In order to determine the patches needed to fix the error, you can simply look at the error message coming from the iasl compiler and the code at the line the error was detected. You can also attempt to apply a patch just to see if it makes changes as shown in the Preview window in MaciASL. If you're not familiar with each type of error, it can take some experimentation and trial/error.Other errors can be fixed by removing/uncommenting the lines causing the error. However, it depends on whether the line is necessary for the proper operation of the code or not. For example, errors caused by
External
declarations can be generally removed to fix the error. If you have any experience with the ACPI spec and some programming experience, this process can be a lot easier to follow. The goal is to get each .dsl
file to compile without any errors. Once you have the files that compile without errors, you can start patching your DSDT/SSDTs to fix the issues you may have with the macOS/OS X installation.External Declratations
// External (DTS1, FieldUnitObj) // (from opcode)
// External (DTS2, FieldUnitObj) // (from opcode)
// External (DTS3, FieldUnitObj) // (from opcode)
// External (DTS4, FieldUnitObj) // (from opcode)
// External (DTSE, FieldUnitObj) // (from opcode)
... and so on ...
ECRW (in a _CRS method).
It's a common error caused by the iasl bug. It can be simply fixed by replacing the code which is given below.Replace this code:
If (LEqual (PM6H, One))
CreateBitField (BUF0, \_SB.PCI0._Y0C._RW, ECRW) // _RW_: Read-Write Status
Store (Zero, ECRW (If (PM0H)
CreateDWordField (BUF0, \_SB.PCI0._Y0D._LEN, F0LN) // _LEN: Length
Store (Zero, F0LN)
with this one :
Store (Zero, ECRW)
If (PM0H)
Store (Zero, F0LN)
Fix *pnp/pnp lower case Error
patch to fix this error.Name already exists in scope (__DSM)
Rename _DSM methods to XDSM
patch to fix the error.syntax error, unexpected PARSEOP_PACKAGE
. Usually relevant for CPU SSDT Sandy Bridge to Broadwell systems. You can apply the Remove _PSS placeholders
patch to fix the error.Invalid type (Target is [Package], Source must be a package also)
. Usually relevant for some GPU SSDT. Note that this error can be related to some other SSDT and as well as other devices than GPU. To fix this issue, you'll need to find the error line and replace PCAP
with Package {PCAP}
(with .aml
extension)VI. Patching the DSDT and SSDTs
Download MaciASL
Branch | Notes |
Rehabman |
Acidanthera |
Copy MaciASL
Category | Patch Name | Required | Notes |
Audio | Layout ID | YES |
Battery | Battery | YES |
Graphics |
| YES | Required for IGPU Power Management. Only use it if you're using IGPU as a Graphics Device.
Fix *pnp/pnp lower case Error | Optional |
AC Adapter Fix | Optional |
Add IMEI | Optional |
Add MCHC | YES |
Fix _WAK Arg0 v1 Fix _WAK Arg0 v2 | YES | ||
Fix Mutex with non-zero SyncLevel | YES |
Fix PNOT/PPNT | Optional |
Haswell LPC Skylake LPC | YES |
HPET Fix | YES | ||
IRQ Fix | YES |
OS Check Fix
| YES |
To check what's applicable for your Laptop, select the patch and check if there is an option to apply. Do not use if using SSDT-XOSI.aml . | |
RTC Fix | YES | ||
Shutdown Fix v2 | |||
SMBUS Fix | YES |
6-series USB 7-series/8-series USB | Injects Power Properties for USB.
USB3 Instant Wake |
Rename B0D3 to HDAU | Optional |
Patch Name | Notes |
Rename GFX0 to IGPU |
Cleanup/Fix Errors (SSDT) |
Remove _PSS placeholders |
Backlight Hotkeys
Battery Status
Backlight Control
VoodooI2C
ASUS SMC
QUICK NOTE:
- Applying patches that are not relevant to your Laptop and applying duplicate patches can cause errors when compiling. Even, if the file does not cause any errors when compiling, the laptop may result in a non-bootable state when using such DSDT and SSDTs.
VII. Compiling
1. Go to File
2. Select Save as
5. Select
under the File Format.6. Click on Save.
NOTE:
- It's a good idea to save the patched DSDT and SSDTs in any other location than the original directory.
For Clover:
EFI/Clover/ACPI/patched
directory.For OpenCore:
EFI/OC/ACPI
directory. You'll also need to add the ACPI entries in ACPI>Add section of your config.plistRecommended configurations for using DSDT and SSDTs
- DropOem=True
Partial Hotpatch:
- DropOem=False
Extra Information
Credits:
