MSI Z590I UNIFY Guide featuring Intel Core i9-10900F, Thunderbolt 4 and AMD RX 5700XT GPU using OpenCore. This guide can be used as a reference for any Z590 Motherboard chipset with very few changes.
Components
MSI Z590I UNIFY LGA 1200 Motherboard with Thunderbolt 4
Already Owned
Intel Core i9-10900F 10th Gen Comet Lake Desktop Processor 12MB Cache 2.9 GHz
Corsair Vengeance RGB DDR4 3200MHz 64GB RAM (2x16GB) ()
ADATA - 250GB PCIe NVMe - M.2 Internal SSD (MZ-V6E250BW)
Fractal Design Define 7XL (CC-9011078-WW)
LG 32" Full HD IPS Monitor with HDMI, and Display Port (LG 22MP58VQ-P)
EVGA 600 BQ, 80+ BRONZE 600W Power Supply 110-BQ-0600-K1
Dell KM636 Wireless Keyboard & Mouse Combo
Comments
The Build
As the new 500 series Motherboard are out, with Thunderbolt 4 so i decided to test Thunderbolt 4. The idea of this build is to use Built-In Thunderbolt. The idea of this build is compact, paired with an i9 10900F running @ 2.9GHz stock speed, having a AMD RX 5700XT 8GB from Sapphire, good power supply with 600W, normal power consumption and a solid performance packed in ITX Build.
Already have a build with MSI Z490I UNIFY and same amount of PCIe slots were needed so the ultimate choice was Z590I UNIFY. It's an ITX motherboard offering support for 10th and 11th Gen. CPUs along with the Thunderbolt 4 support. The motherboard offers built-in Type-C Display. A solid audio codec (Realtek ALC4080), 2.5Gb/s LAN, PCIe 4.0 support for faster data transfer rate. Along with all these, the motherboard supports various features.
Summary
| Features | Status |
| Graphics | YES |
| Built-in Audio | YES |
| DP/HDMI | YES |
| DP/HDMI Audio | YES |
| Ethernet | YES |
| WiFi/BT | YES |
| AirDrop | YES |
| Handoff | YES |
| Thunderbolt 4 Hotplug | YES |
| Power Management | YES |
| App Store | YES |
| iMessage | YES |
| FaceTime | YES |
| iCloud | YES |
| USB 2.0, 3.0, 3.1 and USB Type-C Ports | YES |
Not working
Everything works like a charm.
Bootable Media Creation
2. Plug USB to your system.
4. Close Disk Utility.
5. Open Terminal and type:
6. Enter your password
Preparing OpenCore Bootloader
| Directories | Description |
| Docs | Contains documentation, change log, a sample config.plist, and ACPI Samples for OpenCore. |
| IA32 | Contains OpenCore EFI, 32-bit OpenCore Boot Loader. |
| Utilities | Contains several utilities. |
| X64 | Contains OpenCore EFI, 64-bit OpenCore Boot Loader. |
Adding Required SSDTs
| SSDT Name | Notes |
| SSDT-AWAC |
- This SSDT serves 300 series RTC patch.
- This SSDT is required for all 400 series Motherboards.
| SSDT-EC-USBX |
- This SSDT fixes EC and USB Power.
- This SSDT is required for proper USB Power.
| SSDT-PLUG |
- This SSDT enables Power Management function.
- This SSDT is required for a proper CPU and GPU Power Management.
Adding Required Drivers
| Driver Name | Required | Notes |
| OpenRuntime.efi | YES |
- Runtime driver including several other drivers merged such as ApfsDriverLoader.
- OpenRuntime.efi is a replacement for AptioMemoryFix.efi driver.
| OpenHfsPlus.efi | YES |
- Provides reading of HFS+ Volumes/drives in OpenCore Boot Picker.
| OpenCanopy.efi | Optional |
- Provides GUI functionality for OpenCore Boot screen.
- This driver is required if you need GUI or theme for OpenCore.
| AudioDxe.efi | Optional |
- Provides Boot Chime support.
- Only required if you want to use Boot Chime
3. From the EFI/OC directory, just keep the above drivers and delete rest of the drivers.
- All the drivers can be found at: X64/EFI/OC/Drivers
Adding Required Kexts
| Kext Name | Required | Notes |
| Lilu | YES |
- Provides arbitrary patching.
| VirtualSMC | YES |
- Emulates Apple hardware. VirtualSMC is a successor of FakeSMC.
- This kext requires "Lilu.kext" to function.
| WhateverGreen | YES |
- Provides GPU patching on macOS.
| AppleALC | YES |
- Provides Audio support on macOS.
| NVMeFix | YES |
- Provides NVMe Power Management.
| USBInjectAll | YES |
- Enables USB ports for mapping USB ports further.
- It's advised to map the USB ports during the post-install for a better USB speed, improved sleep/wake and hotplug.
| XHCI-unsupported.kext | YES |
- Enables Unsupported USB ports.
| FakePCIID | YES |
- Provides support for Intel Ethernet Controller.
| FakePCIID_Intel_I225-V | YES |
- Enables Intel Family onboard Ethernet Controller.
- This kext requires "FakePCIID.kext" to function.
1. Download the above kexts.
3. Copy the kexts to:
/EFI/OC/Kexts
Notes:
- Use the kext from RELEASE folder and RELEASE.zip file.
- Do not place unnecessary kexts here. It might prevent booting the installer.
- Only use basic kexts which is required to boot off the installer. You can install the rest required kexts at the time of post-installation.
- The VirtualSMC package includes Battery and Sensors plugins (SMCBatteryManager.kext, SMCDellSensors.kext, SMCLightSensor.kext, SMCProcessor.kext, and SMCSuperIO.kext). You do not need these kexts for booting the installer.
ACPI>Add
| SSDT Name | Notes |
| SSDT-AWAC |
| SSDT-EC-USBX |
| SSDT-PLUG |
ACPI>Patch
| Table Signature* | Find | Replace | Comment | Enabled | Notes |
| DSDT | 50454750 | 47465830 | Rename PEGP to GFX0 (Graphics) | YES |
- Renames PEGP to GFX0 for a better power management.
- This rename is required for implementing discrete GPU Power Management.
| DSDT | 48454349 | 494D4549 | Rename HECI to IMEI (PAVP)* | YES |
- Renames HECI to IMEI for PAVP services.
- This rename is required for implementing PAVP services.
- This rename fixes iTunes/App Store Content Access problems and also enables Content playback.
| DSDT | 4D45495F | 494D4549 | Rename MEI to IMEI (PAVP)* | YES |
- Renames MEI to IMEI for PAVP services.
| DSDT | 48444153 | 48444546 | Rename HDAS to HDEF (Audio) | YES |
- Renames HDAS to HDEF for Audio.
- This rename is required for implementing Audio Function.
Booter>Quirks
| Quirks | Value | Notes |
| AvoidRunTimeDefrag | YES |
- Fixes certain UEFI runtime services such as date time, NVRAM, power control, etc.
| DevirtualiseMmio | YES |
- Remove runtime attribute from select MMIO regions.
- This option reduces stolen memory footprint from the memory map by removing runtime bit for known memory regions.
| EnableSafeModeSlide | YES |
- Patch bootloader to have KASLR enabled in safe mode.
- This quirk requires ProvideCustomSlide to be enabled.
| ProvideCustomSlide | YES |
- Provide custom KASLR slide on low memory.
- This option forces macOS to use a pseudo random value among the available ones.
| RebuildAppleMemoryMap | YES |
- Generates Memory Map which is compatible with macOS.
| SyncRuntimePermissions | YES |
- Update memory permissions for runtime environment.
| ProvideMaxSlide | 0 |
- Provide maximum KASLR slide when higher ones are unavailable.
Note:
- The values which have been not discussed above, that will remain disabled.
DeviceProperties
This section is used for adding device properties. This includes PCI Devices information such as Graphics, Audio, WiFi, Ethernet and other controllers. The following changes are needed.
| Devices | Key | Value | Type | Notes |
- PciRoot(0x0)/Pci(0x1B,0x2)/Pci(0x0,0x0)
| device-id | | DATA |
- Sets Device ID for Ethernet.
F2150000
- Recommended for Intel i225-V 2.5GBe Ethernet chip.
Kernel>Add
| Arch | BundlePath* | ExecutablePath | PlistPath | Enabled | Notes |
| Any | Lilu.kext** | Contents/MacOS/Lilu | Contents/Info.plist | YES |
| Any | VirtualSMC.kext** | Contents/MacOS/VirtualSMC | Contents/Info.plist | YES |
- VirtualSMC is a successor of FakeSMC.
- This kext requires Lilu.kext to function.
| Any | WhateverGreen.kext** | Contents/MacOS/WhateverGreen | Contents/Info.plist | YES |
| Any | AppleALC.kext** | Contents/MacOS/AppleALC | Contents/Info.plist | YES |
- Enables onboard/built-in Audio.
| Any | USBInjectAll.kext | Contents/MacOS/USBInjectAll | Contents/Info.plist | YES |
- Enables USB ports.
- It's advised to map the USB ports during the post-install for a better USB speed, improved and sleep/wake.
| Any | XHCI-unsupported.kext | | Contents/Info.plist | YES |
| Any | FakePCIID.kext | Contents/MacOS/FakePCIID | Contents/Info.plist | YES |
- Required for FakePCIID_Intel_I225-V.kext
| Any | FakePCIID_Intel_I225-V.kext | | Contents/Info.plist | YES |
- Enables Intel i225-V Ethernet Chip
Notes:
- All the plugins must load after loading it's dependencies otherwise the kext will no longer function even when loaded in OS X/macOS.
- The mandatory kexts must be loaded in sorted order as shown in the above table.
- *Indicates BundlePath i.e. Name of the Kext
- **Indicates mandatory kexts.
- All the added kexts must exists in the EFI/OC/Kexts directory.
- The options which have been not discussed above, that will remain untouched.
Kernel>Scheme
| Options | Value | Notes |
| FuzzyMatch | YES |
- Enables checksum ignore with kernel cache instead of using latest cache available.
- This setting allows matching the latest kernel cache with a suitable architecture when the kernel cache without suffix is unavailable, improving macOS 10.6 boot performance on several platforms.
| KernelArch | Auto |
- Determines Kernel Architecture.
| KernelCache | Auto | |
Kernel>Quirks
| AppleCpuPmCfgLock | YES |
- Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in AppleIntelCPUPowerManage- ment.kext, commonly causing early kernel panic, when it is locked from writing.
- Enable this quirk if you cannot disable CFG-Lock in BIOS/UEFI.
| AppleXcpmCfgLock | YES |
- Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in XNU kernel, commonly causing early kernel panic, when it is locked from writing (XCPM power management).
| DisableIoMapper | YES |
- Disables IOMapper support in XNU (VT-d), which may conflict with the firmware implementation.
- This option is a preferred alternative to deleting DMAR ACPI table and disabling VT-d in firmware preferences, which does not break VT-d support in other systems in case they need it.
- Enable this quirk if you cannot disable VT-d in BIOS/UEFI.
| PanicKNoextDump | YES |
- Prevent kernel from printing kext dump in the panic log preventing from observing panic details.
| PowerTimeoutKernelPanic | YES |
- Disables kernel panic on setPowerState timeout.
- Fixes kernel panics related to power changes with Apple drivers in macOS Catalina, most notably with digital audio.
| XhciPortLimit | YES |
- Enables 15 port limit patch.
- This quirk is a temporary solution and is advised to map your USB ports during post-installation.
| DisableRtcChecksum | NO |
- Prevents AppleRTC from writing to primary checksum (0x58-0x59). Required for users who receives safe mode or BIOS reset error after reboot/shutdown. Mainly required for ASUS Motherboards. Do NOT use this quirk is you don't have such encounters.
| DisableLinkeditJettison | YES |
- Disables __LINKEDIT jettison code.
- Provides more reliable performance without keepsyms=1
- This quirk is required for macOS Big Sur.
Note:
NVRAM>Add
| UUID | Key | Value | Type | Notes |
| 7C436110-AB2A-4BBB-A880-FE41995C9F82 | boot-args |
- -v
- debug=0x100
- keepsyms=1
- alcid=11
| STRING |
- Adds boot args which provides several functions.
-v
- Enables verbose mode. Helpful to track the installation progress or when booting.
debug=0x100
- This disables macOS's watchdog which helps prevents a reboot on a kernel panic.
keepsyms=1
- This is a companion setting to debug=0x100 that tells the OS to also print the symbols on a kernel panic.
- This can give some more helpful insight as to what's causing the panic itself.
alcid=11
- Sets Layout ID = 11 for Onboard/Built-In Audio.
| csr-active-config | | DATA | 00000000
- Enables SIP completely. (0x0)
- It's advised to configure SIP via recovery using "csrutil."
- For more information on SIP, check the SIP disabling guide.
| prev-lang:kbd | en-US:0 | STRING | |
PlatformInfo
Suggested SMBIOS
| SMBIOS | CPU |
| iMac 20,1 | Intel Comet Lake for i3 and i7 |
| iMac 20,2 | Intel Comet Lake for i9 |
DataHub
| Option | Value | Notes |
| Add this section in config.plist | YES | Adds DataHub field |
Generic
| Add this section in config.plist | YES | Adds Generic field |
| from SMBIOS | YES | |
| ProcessorType | 0 |
- Sets SMBIOS Processor Type.
- This will override your actual CPU type.
- It's recommended to set this option to "0" to detect the original CPU by macOS instead of using SMBIOS CPU Type.
| SystemMemoryStatus | Auto |
- Indicates whether system memory is upgradable in PlatformFeature. This controls the visibility of the Memory tab in About This Mac.
Auto
- Use the original PlatformFeature value.
- It's recommended to set this option to "Auto."
Upgradable
- Explicitly unset PT_FEATURE_HAS_SOLDERED_SYSTEM_MEMORY (0x2) in PlatformFeature.
Soldered
- explicitly set PT_FEATURE_HAS_SOLDERED_SYSTEM_MEMORY (0x2) in PlatformFeature.
| SpoofVendor | YES | Sets SMBIOS vendor fields to Acidanthera |
PlatformNVRAM
| Option | Value | Note |
| Add this section in config.plist | YES | Adds PlatformNVRAM field |
For more information on Comet Lake config.plist, check the post linked below.
How to Create OpenCore Config.plist file for booting macOS on Intel Desktops An EliteMacx86 Exclusive Guide - This guide covers creation of config.plist for booting macOS on Intel Desktops for OpenCore as a bootloader. Overview The config.plist is a system configuration file for the...
elitemacx86.com
SMBIOS
| Add this section in config.plist | YES | Add SMBIOS field. |
Installing OpenCore EFI
2. Copy the EFI from your working directory to EFI partition of your Bootable USB Flash Drive.
Now you’ve successfully installed OpenCore, the required drivers, kexts and config.plist and the USB Flash drive is ready to boot off your computer.
UEFI Settings
- Set Optimized Defaults.
- Set X.M.P. Memory Profile to Profile 1.
- Set Fast Boot to Disabled.
- Set Windows 8/10 Features to Other OS.
- Set Initial Display Output to IGFX.
- Set Intel Platform Trust Technology (PTT) to Disabled.
- Set Network Stack to Disabled.
- Set XHCI Hand-Off to Enabled.
- Set SATA Mode to AHCI.
- Set VT-d option to Disabled.
- Set Internal Graphics to Auto.
- Save & Exit Setup.
Installation
Turn on your system.
6. Repeat step no. 5.
| Name | Macintosh HD |
| Format | APFS |
| Scheme | GUID Partition Map |
12. Close Disk Utility.
This will take couple of minutes and will restart at "Less than a minute is remaining". Upon completion, the system will automatically restart. The System will restart to complete the installation. Here it ends the first phase of the installation.
Post Installation
Now, configuring the Post Installation. There is not much to do for the postinstallation except configuring Thunderbolt 4 Hotplug and the boot from system drive. Everything rest is fully functional.
To activate Thunderbolt 4, follow the steps from the guide linked below.
How to Enable Thunderbolt 4 Hotplug on macOS [Clover/OpenCore] An EliteMacx86 Exclusive Guide - This guide covers implementation of Thunderbolt 4 Hotplug on macOS for built-in and Add In Card (AIC) Thunderbolt hardware. Overview Recently, Intel and Apple announced their new Thunderbolt...
www.elitemacx86.com
Boot from System Drive
3. Open your
Hard Drive.
6. Copy the
EFI folder from your macOS Bootable USB to your
Hard Drive.
By using this method, you’ll be easily able to install OpenCore Boot loader on your System Drive.
