macOS 上没有 Thunderbolt 3 热插拔。
我刷了自定义固件,但是不能热插拔。
进入系统后,拔出thunderbolt3设备并插入,系统中不识别thunderbolt3设备,thunderbolt树将从40Gb/S变为10Gb/S x 2,thunderbolt3 设备不工作。
有时即使连接了thunderbolt3设备也没有反应,系统桌面上也没有thunderbolt3设备图标,也没有USB3.1总线。
我的配置是微星B460迫击炮+GC-Titan Ridge V2.0。
English only.
My configuration is MSI B460M Mortar + GC-Titan Ridge V2.0.
I have flashed the custom firmware(GC-Titan-Ridge-V2.0-Mod-NVM50-CaseySJ.bin)on thunderbolt card, but it can't be hot-plugged,it can be cold boot only .
After entering the system, unplug re-plug, the thunderbolt device is not recognized, the thunderbolt bus will be removed from40Gb/S becomes 10Gb/S x 2,thunderbolt card is not working,need to restart the system.
Sometimes it doesn't respond even if the thunderbolt or type-c device is connected,There is no Thunderbolt device icon on the desktop, and there is no USB3.1 bus.
Can you help me?
  • DSDT.aml.zip
    DSDT.aml.zip
Can you help me?
Incomplete PR files.
Read the PR files requirement in the first post.
Details:
1. Thunderbolt Chip and Family: GC-Titan Ridge 2.0 (JHL7540)
2. Thunderbolt Vendor/Manufacturer: Gigabyte
3. Thunderbolt Type (Onboard or AIC): AIC
4. Thunderbolt AIC PCI Slot Location: Slot 2(Second slot)
5. THB_C header Availability: Yes and plugged in
6. TB BIOS Settings Availability: Yes (set to no security)
7. Motherboard Model: MSI B460M Mortar
8. CPU Model: Intel Core i5 10400
9. macOS version: Catalina(10.15.7)
10. Copy of IOReg: attached(IOReg-Qin’s iMac)
11. Kextcache output: KernelCache ID: 6B152F4687C1729C70559D3472DBAE58
Notes:
.I have flashed the custom firmware(GC-Titan-Ridge-V2.0-Mod-NVM50-CaseySJ.bin)on thunderbolt card, but it can't be hot-plugged,it can be cold boot only,but sometimes can not be recognized.
.After entering the macOS, Unplug and reinsert, the thunderbolt device is not recognized, the speed will be removed from 40 Gb/S x1becomes 10 Gb/S x2,but the thunderbolt card is not working,need to restart the macOS.
.Sometimes it doesn't respond even if the thunderbolt device or type-c device is connected,there is no thunderbolt device or type-c device icon on the desktop, and there is no USB 3.1 bus,thunderbolt device tree’status display: no devices connected.
.Please help me,Thank you.
Details:
Notes:
TB implementation seems to be fine. However, the configuration is not as per the guide.
Try to reset your BIOS and then setup your BIOS again.
Thank you, I'll try again.
After replacing PCI0 with PC00 according to the guide, restart the system and cannot enter MacOS.
You need to use your ACPI path. If it's PCI0, use PCI0. The guide i referred to was the OC guide. Not the TB guide.
Details:
7. Motherboard Model: Z390 Aorus Pro WIFI
8. CPU Model: Intel Core i7 9700k
10. Copy of IOReg: attached(imac pro IOReg)
11. Kextcache output: KernelCache ID: 7C8FAE5B13FF5570DD6A0EE5104A5C5A
Hi! I've just use only one Titan Ridge V2 card with original firmware, I've just follow instruction but I can't enable hotplug, please help!
  • iMac Pro.ioreg.zip
    iMac Pro.ioreg.zip
  • OC.zip
    OC.zip
Details:
Your configuration is not as per the guide. Provide your BIOS settings too.
wyattst99
