App Store not installing apps
Nothing happened. Also I changed to wifi because I found a kext for it. Problem still exists.
Reset App Store settings. Make sure your Country settings are correct.
I mean how to I make sure my country settings are correct?
I did what you said. Problem is the same. It's stuck at 70.1mb/70.1mb.
If the file size is also 70mb. If the file is 124mb, then it will get stuck at 124mb. So it gets stuck at exactly the file size, and the install never starts.
  • Locate ~/Library/Caches/com.apple.appstore and delete com.apple.appstore which are cache files.
  • Then press again those commands and go /private/var/folders, open each folder and each subfolder until you find com.apple.appstore and delete this folder.
  • Restart
ryusuke17
