I only use Thunderbolt for audio with my Apollo Twin. That's all I plan on using it with for now.
Not necessary to flash. Just use Hotplug and you're good to go.
Hmm. I have the hotplug and everything pointing to the AIC. The card is recongized in the system but the audio interface isn't being recognized at all.
No PR files attached.
PR:
  1. JHL7540 Titan Ridge
  2. ASUS
  3. AIC
  4. Slot-6
  5. YES
  6. YES
  7. ASUS Prime Z490-A
  8. i7 10700k
  9. Big Sur 11.3.1
Incomplete PR files attached.
The speed shouldn't be 0Gb/s. Update your TB firmware from Windows and test the Interface in Windows. The ideal slot location for your Motherboard is Slot 4. Disable TB SSDTs. Install it in Slot 4 and. provide a complete PR files, attached in one single .zip file.
Updated the TB firmware version to the latest one I could find. The interface was still recognizable on windows. I disabled the TB SSDTs. Here's the PR with the SSDTs disabled.
It shouldn't show as Express Card and bandwidth to 0Gb/s. What TB Card are you using? And which firmware?
I'm using ASUS Thunderboltex 3-TR (15EB) on NVM firmware 56. Here's what the control center shows too.
Is this original firmware?
copperbarg
