Asus Z590-P - i5-11400 - AMD RX 5700XT - OpenCore Big Sur (Solved)
hamed
Asus UX501VW
Core I7 6700HQ
Intel HD530
  1. iMac Pro
Hello,
I successfully installed Big Sur on my build with
MB: Asus Z590-P
CPU: Core i5 11400
GPU: Radeon RX580 & RX5700XT (both work)
everything is working fine except my audio, I installed AppleALC and added alcid (69 and 66) in boot-args.
as you can see the output device shows up in the sound settings but it doesn't make any sound and when I change the volume the settings window is laggy.
what is the problem?
here are my configs Link
Hello,
MB: Asus Z590-P
CPU: Core i5 11400
Incomplete PR files attached.
IOReg is missing.
Kextcache output is missing.
The problem is solved and everything is working now,
here is the EFI Link
hye! do you mind sharing how you get it running on i5-11400. My motherboard is z590 vision g. And how did you get the ssdt for the respective hardware. Thank in advance!
A guide is already available for your Motherboard
but im running it on i5-11400, an 11th generation intel cpu, is spoofing the cpu necessary to get it to install?
Yes, correct. It is necessary.
The link is broken - Can you sen a new one? I have the same motherboard Asus Z590-P
natsukiro
