Audio not working in Mojave
nothing, no sound, i patched de DSDT.aml and nothing
The DSDT has a valid layout ID. But your DSDT has not been patched properly. Use IRQ Fix in your DSDT.
Reply with new files.
petched the IRQ Fix and the same
Use this app: Mac Optimizer
Use the second tab and reset the nvram and rebuild system caches.
Make sure that SIP is disabled.
i do and nothig. The same
The issue is from the AppleHDA itself.
Remove the AppleHDA from S/L/E
Restore vanilla AppleHDA in S/L/E. Read here: https://www.elitemacx86.com/threads/guide-restoring-native-vanilla-applehda.270/
Restart and then patch the AppleHDA.
Patch your AppleHDA using the v1.8.
Use layout ID=3
You should have a working Audio.
i do, and the same
there are the changes
i do, and the same
Well, i tested it on my another Laptop with Mojave. Tested both the patcher but no audio.
The fix is, you'll need to use AppleHDA Patcher v1.8 only. The AppleHDA should not be from Mojave but from High Sierra.
I've updated the guide for the same.
AppleALC and Lilu still not removed.
The AppleHDA Patcher that I have used this last time is the one you told me, the 1.8, not the 1.9, and it has not worked for me.
what can I do now?
what can I do now?
Yes, it will make no difference. As i mentioned above, the post has been updated now. Basically, you'll need to use a AppleHDA from old macOS version such as High Sierra or earlier and then install it to S/L/E, build caches and do a restart.
Once the previous version of AppleHDA is installed, patch the AppleHDA using AppleHDA Patcher v1.8. Use layout ID=3 and you should have a working Audio.
This can called be a bug in the patcher itself which doesn't patch as per the expectation.
that's the last thing I've done, create the kext with applehda patcher 1.8.
install the kext that is in the full kext folder, then patch with Maciasl the DSDT.aml of the acpi patched folder and apply Lyout id = 3 and after restarting it remains the same.
Please read my above message and also check the updated guide.
incer01
