Kernel Extension in Backtrace : com.apple.driver.AppleIntelBDWGraphicsFramebuffer(14.0.4)
Monsters
Dell Vostro 3558
Intel Core i3 5005U (Broadwell-U)
Intel HD Graphics 5500
10.14.x
Hello,
I am new to Hackintosh Community, i am trying to install MacOS Catalina on my dell laptop.
But i get kernel panic whenever i boot into installer like this.
Please i need help , i am also attaching my EFI and image specifying about the KP issue.
Please have a look.
My laptop specifitcations:
Name : Dell Vostro 3558
Processor : Intel Core i3 5005U (Broadwell-U)
Graphics : Intel HD 5500 and Nvidia 920m
Opencore Version : 6.3
MacOS Version : 10.15.3
  • EFI.zip
    EFI.zip
Hello, I am new to Hackintosh Community, i am trying to install MacOS Catalina on my dell laptop. But i get kernel panic whenever i boot into installer like this. Kernel Extension in Backtrace : com.apple.driver.AppleIntelBDWGraphicsFramebuffer(14.0.4) Please i need help , i am also attaching my EFI and image specifying about the KP issue. Please have a look. My laptop specifitcations: Name : Dell Vostro 3558 Processor : Intel Core i3 5005U (Broadwell-U) Graphics : Intel HD 5500 and Nvidia 920m Opencore Version : 6.3 MacOS Version : 10.15.3
That's because of insufficient DVMT Pre-alloc memory on your Laptop. You can use the framebuffer patch or can manually unlock the DVMT Pre-alloc.
Is the SMBIOS and platform id good for my laptop?
Also i had used the framebuffer patch but still getting this error.
And in BIOS my video memory is set to 64mb , cannot be changed.
I tried the rehabman's invalid platform id and installed the Mac os successfully.
After completing the whole procedure i rebuilded the kext cache using the command from the above link.
After adding the framebuffer patch to my config.plist i booted again.
But now i am having this kernel panic.
I am attaching the Image and my config.plist please have a look.
  • config.plist.zip
    config.plist.zip
Incomplete PR files attached.
I cannot boot when using the required platform-id,
so not able to post PR files.
Or should i post PR files using the invalid platform-id
You can use the invalid ig-platform-id and provide PR files.
Here are the PR files
sims10981
