GPU acceleration (I tried everything)
UltraFlame009
DELL latitude 3450 (OpenCore)
Intel i3 4005U
Intel HD 4400
10.13.x
  1. MacBook Air
Install, post install, it all worked. Even got ethernet to work. But I nee help with graphics.
I tried everything, but it either does nothing or stops boot. I restored original EFI, but I need help here
Only 4mb VRAM :(
Here's my EFI, anyway-
Thanks in advance!!!
Only 4mb VRAM :(
Your configuration is not upto the mark.
Ok, i'll redo it. Hope it works!
with OC 0.6.9
Ok, I rebuilt it. Anyway to fix the GPU now?
Don't mind the OCEFI name, will rename it...
I also want HDMI to work (google says its related to VRAM) because the Dell screen has a bit of bleed issue.
No, you did not. The files are not as per the guide.
Ohh, so its the config.plist, isn't it? (And files, some are missing)
Will get back with fix, even try booting it.
Sorry for all this, was just eager :p
Ok, I added some ACPI patches. At this point I don't know what to do, so if possible, can you fix any other issues?
This is my first time hackintoshing, so I am quite new
P.S. I added the resources for the GUI, but its not in the ZIP.
You don't have Device Properties set for IGPU. No framebuffer is present. Follow the guide.
moraWooChang
