Audio not working in Mojave
Hello to all, As the title says is what happened to me, create a pendrive with the latest version of clover, and update Mojave from 10.13.2 and all good, when I start everything was fine until I put a song and saw that I had no sound, look and see that I do not recognize anything of audio devices, could someone help me to have sound again?
Hello and welcome to EliteMacx86
Use IOJones and save the report and post it here so we can see what's going on with your Audio Layout-ID.
my audio codec is realtek ALC898
Mac Os version 10.14
Copy of IOReg i dont now
installed AppleHDAkext of AppleHDAPatcher 1.9
Your screenshots shows the Audio is running. So what's the problem? No output?
No AppleHDA.kext attached as requested.
Also, no layout is injected in your DSDT. And you're using wrong Layout ID. For the macOS Mojave, you should use layout ID=2 as per the AppleHDA guide.
Change the Layout ID to 2 in your config.plist and reply with the new files.
Also, you're using two methods. Only use one otherwise they'll conflict. Remove AppleALC and Lilu.
the audio appears, but no sound, the layout is in number 2, i changed.
with the AppleHDA
I suggest you clean the nvram and rebuild the system caches since the Audio is detected and it's active and see if that helps.
nothing, no sound, i patched de DSDT.aml and nothing
how can i do?
incer01
