News Now you can use Antelope, PreSonus, Slate Digital, Focusrite and Apogee Thunderbolt Audio Interface and NAS on Custom PC Builds and Laptops with macOS
Wow, I just bought an Antelope Audio Zen Tour Synergy Core under the impression that I'd be able to use it with my Z490 build. Then I saw this thread, informing me both that it isn't possible, and it IS possible at the same time!
I would absolutely love to be a tester!
My setup:
AA Zen Tour Synergy Core
MacOS BigSur 11.4 (20F71)
Boot: OpenCore 0.6.9
Intel Core i9-10900K
Asrock z490 Phantom Gaming-itx/tb3
AMD Sapphire RX 570
I just upgraded to Big Sur and I'm not sure if I'm going to stick with it or go back to High Sierra. I don't know how that affects the solution.
Exactly!
Normally, it has not been possible over the years but the solution is here and very soon it will be released publicly.
We appreciate your participation. Our mods will reach you out as soon as possible. Refer to post #2 for additional details.
That's definitely not an issue. The solution works on Big Sur.
你好,我准备成为一名测试员。
技嘉-Z390-GAMING X
CPU:I7-9700K
显卡:AMD-R9 280X
Titan Ridge-V2.0 带原装固件
OS X/macOS:10.15
SoundCard: Antelope Zen Tour
你好,我准备成为一名测试员。
GIGABYTE-Z390-GAMING X
CPU:I7-9700K
Graphics:AMD-R9 280X
Titan Ridge-V2.0 with Original Firmware
OS X/macOS:10.15
I am ready to be a tester, I have antelope Orion studio 2017 interface and hackintosh, they are not able to find each other , may I have the solution for my audio interface. Tks.
万岁!我的 AntelopeZen Tour 现在正在通过雷电连接工作。模组从头开始重新配置我的系统,他们将引导加载程序迁移到 OpenCore,当系统完全配置后,我的所有硬件都开始完全工作。没有延迟,我可以使用 AFX2DAW,并且可以使用任何采样率。一切都没有中断地切换,系统看到的卡就像在原来的 macbook pro 上一样。非常感谢!我向使用 Hackintosh 的 Antelope 用户推荐此解决方案!我在下面附上截图。
我的设置:
主板 Z390 Designare
CPU 酷睿 i9 9900k
显卡5700XT硝基版
macOS 10.15.7
声卡:羚羊禅之旅
I have the same Zen Tour sound card as you, so I envy you. I hope I can use it soon too!
我有和你一样的Zen Tour声卡,所以我很羡慕你。我希望我能很快
Use English only. You already agreed to the terms when signing up on this forum.
Hello, Guys. How can I be a tester?
I got an Antelope Synergy Core 8
xmax114
