I did read it, but I don't understand how to insert my 5 part path in a 3 part path in the SSDT. How do I split it to do the replacement when doing the find+replace thing..?
Read "For Multiple Thunderbolt Cards" section
Ran in this. Am I going in the right direction?
It should look like following
    External (_SB_.PCI0, DeviceObj)    // (from opcode)
    External (_SB_.PCI0.GPP1.PT02.PT20, DeviceObj)    // (from opcode)
    External (_SB_.PCI0.GPP1.PT02.PT20.X162, DeviceObj)    // (from opcode)
    External (DTGP, MethodObj)    // 5 Arguments (from opcode)
    If (_OSI ("Darwin"))
        Scope (\_SB.PCI0.GPP1.PT02.PT20)
            Scope (X162)
                Name (_STA, Zero)  // _STA: Status
            Scope (X162)
Oh ok got it! Understand it now! It now shows up in the PCI tab in System Report, but when I plug in a USB-C device, nothing shows up. Anything else to do or to know?
Thanks a lot again mate! Really helping an SSDT noob a lot!
No PR files attached.
  1. ThunderbolEX 3-TR / TITAN
  2. ASUS
  3. AIC
  4. Slot 2
  5. THB_C connected to the card
  6. No TB BIOS Settings
  7. ASUS B550-F WiFi
  8. AMD 3900X
  9. 11.2.1
  10. Attached
  11. Kextcache output
  • Will’s Mac Pro.zip
    Will’s Mac Pro.zip
  • OC.zip
    OC.zip
  2. ASUS
  3. AIC
  4. Slot 2
  7. ASUS B550-F WiFi
  8. AMD 3900X
  9. 11.2.1
  10. Attached
Thunderbolt implementation seems fine. What TB Device are you testing?
I'm just testing USB-C right now, all my TB devices are in luggage right now. But USB should work right?
Is that a USB Type-C flash drive? Yes, the Type-C device should work.
It's an external SSD connected with a USB-C cable. Nothing fancy. I'll test some more tomorrow!
Thanks mate
danh.hnad8877
