Ok great! I'll try to flash it as soon as I land in Indonesia next week! I don't have my TB in hand right now, but if I did, would it still work without the hotplug capability?
Thanks again!
Flashing or without flashing, with the help of SSDT, you can have Hotplug functionality.
OK good! But right now, when I plug a USB-C device in it, I can't see it show up. I tried with multiple USB-C devices. My external SSD has the light flashing, but not connecting.
You should attach problem reporting files containing all the information.
  1. ASUS ThunderboltEX 3-TR / TITAN
  2. ASUS
  3. AIC
  4. Slot 2
  5. THB header connected to the said card
  6. No TB BIOS settings
  7. ASUS B550-F WiFi
  8. AMD 3900X
  9. macOS 11.2.1
  10. IOReg copy in files
  11. Kextcache output, I'm not sure what it is.
  • OC.zip
    OC.zip
  2. ASUS
  3. AIC
  4. Slot 2
  7. ASUS B550-F WiFi
  8. AMD 3900X
  9. macOS 11.2.1
Incomplete PR files attached.
Kextcache output and IOReg are missing.
To generate kextcache output, use the below command in Terminal
Sass:
sudo kextcache -i/
Sass:
sudo kextcache -i/
Sorry, missed the IOReg. Here they are!
  • Will’s Mac Pro.zip
    Will’s Mac Pro.zip
Your SSDT is not adapted correctly for the system. The IOReg has the following path.
PCI0.GPP1.PT02.PT20.X162
Whereas, your SSDT has the following address which is incorrect.
PC00.PT02.X162
Thanks for the info! I'm a bit lost on where to put what in the SSDT though aha first time for me going that deep in this stuff. Don't want to ask too much, but is there a way you could send me a corrected file I could compare with my old one and learn from it?
No. You should consider reading the guide. The guide already explains how to change your ACPI path.
I did read it, but I don't understand how to insert my 5 part path in a 3 part path in the SSDT. How do I split it to do the replacement when doing the find+replace thing..?
dodikhokh
