HP 15 dk0xxx frequent restarting
I tried with open core instructions but not succeeded I am attaching the efi and photo can you check where is the error happened
Can you help me now where is the problem
I found the problem with samsung NVME PM981, i tried with open core when i trying to format or install in nvme computer is stuck and need hard resetting, when using clover restarting instead of stuck. Is there any way to disable nvme by config plist. No problem in installation in hard disk
Yes, you can use the DSDT to disable it.
How to disable with dsdt in open core
ryusuke17
