So I just had time to continue with the installation, I followed your instructions and boom, everything worked like a charm. Thanks a lot!
Great. :)
So I just want to know how to make the sleep function work and how to make cover have a timeout when booting.
Create a separate thread.
Once the laptop has booted, Clover doesn't automatically choose the boot volume, so is there anyway I can change this?
Yes, read here:
Thank you for this guide
I have a tablet PC. Unfortunately the picture is displayed via external HDMI instead of internal LCD.
There are two config.plist files. I tried both, the same result .
Thanks in advance for any help
Hi, when installing the chris1111 driver, I see a line that blinks every time I enter a program.
This line is horizontal, any idea what happens or how to solve it? I am using Mojave MacOs
Hi guys, Catalina Hackintosh here, trying out the updated video patch but this error comes out and make my system crash every time I re-install, I do not see this issue from others that's why I posted. My Dell N4050 Intel HD 3000 runs with Mohave just fine, I just need this patch so bad, or if there's another workaround Im all eyes.
Im using:
Clover Legacy Bootloader
Thanks,
Im using:
Thanks,
Re download and check.
Okay I will try again, this time I will do it on my final Catalina internal SSD installed to my Dell N4050,
Crossed finger as I already had enough breaking my install progress, spending too much time already.
I will report back the result.
thanks.
By the way how can I rollback if things get messed up again?.
thanks.
What do you need to rollback?
Each time I hit that script error, it freezes catalina, leaving me no other choice but to press that power button and hopeful for the reboot to regain access to the desktop. Unfortunately the dreaded "amfi" or "Too Many Corpses" messages floods on startup.
You'll need to provide more information. What macOS version are you using?
Sorry unable to reply quick, my last install blew up again before I got to try your "Re download again and check".
Using Catalina 10.15
and upgrading to 10.15.7
Write your reply...
0xdbh
