Laptop: Samsung np300e4z-s06vn
CPU: Intel Core i3-2350M/HM65
Graphics: Intel HD Graphics 3000, 1366x768
Bootloader: Clover(UEFI)
Vram just get only 3mb
can my hackintosh get full resolution?
Incomplete PR files. No kextcache output attached.
The configuration is a mess. You cannot expect it to work.
Note: If you're having a UEFI Laptop, only use UEFI. If you're having a Legacy one, use Legacy only. (Clover drivers)
how to complete pr file and get kextcache output file?
I'm a noob in hackintosh. So I installed Mojave on my ProBook 4530s with clover
After following this guide, My system I stucked at ACPI error.
I tried injectIntel but it still refused to work
I was only able to boot in after I used injectIntel with fakeID= 0×0001000
After booting the graphics was not yet updated
I have attached my clover file and all other screenshots.
You're using a distro. Remove it and install vanilla.
Reactions: eryoungboy
I don't have a MacBook to create install media. So is there any way around to make the Intel hd 3000 work ?
Use the current installation for the same.
Okay. Thanks a lot
I will try it and get back to you
Just one more question, can I pause the download from app store? Or is it possible to download the Install macOS Mojave.app from an external location
Okay. Thanks a lot
Yes, you can pause. But i don't recommend doing that.
So I just had time to continue with the installation, I followed your instructions and boom, everything worked like a charm. Thanks a lot!
So I just want to know how to make the sleep function work and how to make cover have a timeout when booting. Once the laptop has booted, Clover doesn't automatically choose the boot volume, so is there anyway I can change this?
wyattst99
