App Store not installing apps
Just found it, and now I am left with launchpad says it's downloading and i can't download the apps. It just stops after the spinning icon.
Consider a clean install. Already you had tons of issues.
But I have lots of data already on it. Any other method, or I really need to do a reinstall?
Also, Launchpad fixed. Now files are downloading, but still not installing.
Performed clean install. Now it's stuck at Waiting... . But it's better because I can stop downloading from app store and launchpad is not buggy.
Try any other App such as Whats App.
Same problem. Should I try resetting app store caches?
Not worked. Other help?
Write your reply...
ambruhidot
