[SOLVED] App Store not downloading apps and can't login
Kernel
Dell G15 5510
Intel Core i7-10870H
Intel UHD Graphics 630
Hello!
I have macOS Big Sur 11.0.1 and there is one big problem. I can't download or update apps from app store. I press the button, it starts spinning, then goes back to the button. Also, I logged off the app store to log back in, but I can't log back in. I enter my apple id details, press log in, but nothing happens. Same from System Preferences when I want to modify App Store settings.
Can someone help?
Hello!
Can someone help?
There are some related issues.
No PR files attached.
There is it.
And I forgot to mention that i'm using ethernet.
How do I implement CPU PM?
Is this a good file for my i5-4210U processor?
For Haswell, you don't need any addon SSDT for CPU PM. Make sure you're using the correct config.plist.
Is this correct? If not, how do I fix it?
Still no change.
And I noticed this is only an issue on App Store. I can log in into System Preferences, Music, Podcasts, TV, but I can't log in into Books, App Store. I cleared App Store cache, and now it doesn't show updates.
PR attached.
lovos33
