[SOLVED] macOS Catalina and Intel HD 4400
What drivers do I need to install? I can't find it in the list.
Attached new pr files
Wait. You don't have to help further. The problem got solved. How? I used the right config.plist file.
Thanks for the help. This is the best mac forum!
Yes, that's correct. However, i need to check your new IOReg. Also, the screenshots are old too. Attach them again, a fresh one. Hopefully, the issue is fixed but i need to check it at my end.
There is it.
Reactions: anceng
There is it.
The acceleration seems to be working. Mark the thread SOLVED.
Additional info:
-Couple of kexts are corrupt and must be restored to a vanilla state. Using this configuration, do a combo update of 10.15.7.
-Remove BrightnessFix from ACPI/patched.
-Remove off directory from drivers directory.
-Still, the drivers are not as per the guide.
-Remove 10.15 directory from kexts directory.
-The kexts are not as per the guide. IntelBacklight is depreciated.
OhCamargo
