How to Disable Discrete Graphics in Dual GPU Laptops (NVIDIA/AMD) on macOS
An EliteMacx86 Exclusive Guide - This guide covers disabling Discrete Graphics in Dual GPU Laptops for NVIDIA and AMD on macOS. By following this guide, you'll be able to disable discrete graphics (NVIDIA/AMD) on your Dual GPU Laptops on macOS.
Many laptops have dual graphics such as AMD Radeon or NVIDIA Geforce which utilizes a switching mechanism to switch from the integrated graphics(Intel HD) to the discrete graphics as per the graphics demand. When using NVIDIA, this feature is referred to as Optimus Technology and AMD is referred to as AMD Switchable Graphics. When enabled, both IGPU and NVIDIA or AMD will be activated and will work under Optimus/Switching mode. However, this type of technology is not supported on Non-Apple computers when running macOS/OS X and should be disabled for a better cause to save power and generate less heat, improving the battery backup. However, a disadvantage can be that you cannot use such Laptops for graphics-hungry applications when running macOS. Users not having such needs can continue to disable the discrete graphics for a good cause and can have the advantage of more battery backup.
Disabling discrete Graphics is mandatory when having an Optimus or Switchable Graphics Technology as it can be difficult to install macOS and to save Battery life within OS X/macOS, which will generate less heat and noise. When Discrete Graphics isn't disabled, the GPU draws power even if it does not work on OS X/macOS. This can also cause sleep/wake failure. See Fixing Sleep for more information on Sleep/Wake.
For Disabling Unsupported IGPU
elitemacx86.com
Available Methods for Disabling Discrete Graphics
Following are the methods available for unlocking the Discrete GPU. All these methods have been described below.
This guide covers the disabling of discrete graphics in dual GPU laptops. The dual GPU laptops come in two variants:
Using BIOS, you can disable the discrete GPU in Laptops. Disabling the discrete graphics in BIOS is not the best option as the device will be disabled in macOS as well as on Windows. To overcome this issue, you need ACPI patching which is a better option and the discrete GPU can be used in Windows or Linux. Most of the manufacturers do not give the option to disable the discrete Graphics under BIOS. However, a few manufacturers such as Clevo, Razer Blade, Lenovo, and Dell, do give the option to disable some of the selected models. If you disable it under BIOS, no need to patch the ACPI to disable the dGPU. However, if you keep the option enabled (to use it on other OS), you need to patch ACPI to disable the dGPU.
Method #2: Disabling Discrete Graphics using Kext
Using WhateverGreen, you can use a Boot Arg or a Device Property and can disable the discrete GPU in Laptops.
STEP 1: Add Required Kexts
The next step is to add the required kexts to disable discrete GPU. WhateverGreen doesn't work standalone. WhateverGreen and Lilu are needed together to work in conjunction in order to disable the discrete Graphics. This step shouldn't be required if you have followed the Installation Guide. However, if not, follow the steps below to add the kexts.
1. Download AppleALC and Lilu from the downloads section of this forum.
For Clover:
If you're using Clover, copy both the kexts to
For OpenCore:
If you're using OpenCore, copy both the kexts to
STEP 2: Add Required WEG Properties
The next step is to add the WEG properties to the config.plist which will disable the discrete Graphics. Only use one of the methods, not both.
1. Mount your ESP.
Using Boot Arg
Depending on the bootloader you use, add the boot arg to your config.plist to disable the discrete GPU.
For Clover
1. Open config.plist from EFI/Clover directory
2. Go to the Boot section. Add
For OpenCore
1. Open config.plist from EFI/OC directory.
2. Go to the NVRAM section. In the UUID
Using Device Properties
Depending on the bootloader you use, add the following property to your config.plist to disable the discrete GPU
2. Save config.plist
Method #3: Disabling Discrete Graphics using ACPI Patching
Using DSDT and SSDT method, you can disable the discrete GPU in Laptops and this is considered a more optimal and robust solution than method 1 described above.
A laptop from ASUS (X302LJ) has been used as an example for this guide which features Intel HD Graphics 5500 and NVIDIA Geforce 920M. The ACPI files have been extracted using the Clover F4 method. The native(untouched) files are under the origin folder and the patched ACPI files are under patched. The files have been provided in the attachment of this post.
Before you start with this guide, I recommend you to read about DSDT and SSDT patching on laptops. The guide covers the extraction of the ACPI files, disassembly, compiling, patching, saving, and installing. Read here:
To extract DSDT and SSDTs
elitemacx86.com
For patching DSDT and SSDTs
elitemacx86.com
STEP 1: Finding the required methods
To disable the DGPU, you'll need to find _OFF and _INI Method defined in your ACPI tables.
Finding _OFF Method
First, you'll need to find the SSDT with _OFF Method. To know this, we can use grep.
Open Terminal
Move to the working directory, where you dissembled the files.
Type:
Which results:
Note down the SSDT with _OFF Method.
Finding _INI Method
Also, you need to find the DSDT and SSDT which contains the _INI Method
Type:
Which results:
Note down the DSDT and SSDT with _INI Method.
Separate those DSDT and SSDT to any other directory.
But you need to confirm which exact SSDT has both the methods. To do so, follow the instructions below
Open the SSDT one by one and search for "Method (_INI". This is SSDT which needs to be patched.
When searching for the _INI method in "SSDT-10-SaSsdt.dsl", we find 4 _INI methods:
The second _INI
The third _INI
And the fourth _INI
In this case, none of the methods contains the address of the discrete graphics device. So we need to look for the other SSDT searching the same _INI method.
When searching for the _INI method in "SSDT-11-SgPch.dsl", we find one _INI method:
This is the SSDT we're looking for. This SSDT contains the address of the discrete graphics device.
If you look for the same method in "SSDT-12-OptTabl.dsl", we find one _INI method:
But this is not the SSDT we're looking for as it doesn't have any _INI method with the discrete graphics device address.
So we've got the _INI and need to look for the _OFF method. It's pretty clear that the path to _OFF should also have \SB.PCI0.RP05.PEGP-> _OFF
So, we know that the _OFF is located in either SSDT-10-SaSsdt.dsl, SSDT-11-SgPch.dsl or SSDT-12-OptTabl.dsl
When searching for the _OFF method in "SSDT-10-SaSsdt.dsl", we find 3 _OFF methods:
The second _OFF
The third _OFF
In this case, none of the methods contains the address of the discrete graphics device. So we need to look for the other SSDT searching the same _OFF method.
When searching for the _INI method in "SSDT-11-SgPch.dsl", we find one _OFF method:
If you look for the same method in "SSDT-12-OptTabl.dsl", we find one _OFF method:
But this is not the SSDT we're looking for as it doesn't have any _OFF method with the discrete graphics device address.
Now, we've got the SSDT which contains the _INI and the _OFF method. Now we need to look for the errors if any.
Compile the "SSDT-11-SgPch.dsl". Upon compiling, it has no errors. So we're good to go.
Now the patches can be applied.
STEP 2: Patching SSDT and DSDT
The next step is to patch the SSDT and DSDT to disable the DGPU.
Patches (SSDT)
[igpu] Rename GFX0 to IGPU
[gfx0] Disable from _INI (SSDT)
Patches (DSDT)
[gfx0] Disable from _REG (DSDT)
Applying the Patches
For SSDT :
Open the "SSDT-11-SgPch.dsl" using MaciASL.
Click on the Patch button
Find and select the patch from the left pane.
When applying the second patch, the patches will not get applied because of the incorrect address of the discrete graphics device. We need to replace the address of the graphics device. See notes below.
The default patch:
which doesn't gets applied.
The modified patch (PEG0 changed to RP05):
Click on Apply.
After applying the patch, the patched SSDT will read:
Click on Close.
For DSDT :
For new Laptops
On several new Laptops, the patches will not be applied as there's no any _INI method. To fix this, follow the steps below.
1. Find the SSDT which has the _OFF method defined for the GPU.
2. Locate the GPU address in your SSDT, for e.g., \_SB.PCI0.PEG0.PEGP.
3. Find the _OFF method. It will be exact as "Method (_OFF, 0, Serialized) // _OFF: Power Off"
4. Above _OFF method in your SSDT, add "Method (_INI) {_OFF() } // added to call _OFF"
5. Apply the following patch
6. Click on Apply.
7. Click on Close.
For DSDT :
Open the DSDT using MaciASL.
Find and select the patch from the left pane and click on Apply.
When using the second patch, the patches will get applied but we need to replace the address of the discrete graphics device. See notes below.
The default patch:
Click on Apply.
After applying the patch, the patched DSDT will read:
Click on Close.
Compiling
After patching the DSDT and SSDTs, you need to compile the files.
Simply click on compile and look for errors. If there's an error, fix it and again click on Compile.
If there's no error, the files will be compiled successfully.
Note:
STEP 3: Saving the ACPI files
After compiling, the next step is to save the file for the installation.
1. Go to File
2. Select Save as
3. A dialogue box will appear asking for the location and the file extension to save the file.
4. Select ACPI(ACPI Machine Language)
5. Click on Save
Note:
Conclusion
DSDT.aml (includes _REG patch)
SSDT-11-SgPch.aml (includes _INI and _OFF patch)
STEP 4: Installing the DSDT and SSDT
The next step is to install the DSDT and SSDT. To install the DSDT and SSDT, follow the steps below.
1. Mount your ESP
For Clover:
If you're using Clover, copy all patched DSDT and SSDTs to EFI/Clover/ACPI/patched
For OpenCore:
If you're using OpenCore, copy patched DSDT and SSDTs to EFI/OC/ACPI. You'll also need to add the ACPI entries in ACPI>Add section of your config.plist
STEP 5: Restart your System
The discrete graphics device should be disabled now.
Problem Reporting
Details:
Credits :
Sample Attachment
The ACPI files are attached below which have been used as an example in this guide:
GUIDE - How to Disable Unsupported IGPU (Intel Graphics) on Desktops and Laptops
How to Disable Unsupported IGPU (Intel Graphics) on Desktops and Laptops This guide covers disabling Unsupported IGPU (Intel Graphics) on macOS. By following this guide, you'll be able to disable unsupported IGPU on your Desktop or Laptop under macOS. Overview Many Intel CPUs have graphics...
elitemacx86.com
| Methods | Remarks |
| BIOS Level |
| Kext Level |
| ACPI Level |
- Intel+NVIDIA (Optimus Technology)
- Intel+AMD (Switching Technology)
For Clover:
EFI/Clover/Kext/Others directory.For OpenCore:
EFI/OC/Kexts directory. You'll also need to add the kext entries in the Kernel section of your config.plist.NOTES:
1. Mount your ESP.
Using Boot Arg
For Clover
-wegnoegpu under Boot Arguments.For OpenCore
7C436110-AB2A-4BBB-A880-FE41995C9F82 add -wegnoegpu under boot-args.Using Device Properties
| Devices | Key | Value | Type |
| PciRoot(0x0)/Pci(0x2,0x0) | disable-external-gpu | 01000000 | DATA |
GUIDE - How to Extract DSDT/SSDTs
How to Extract DSDT/SSDTs An EliteMacx86 Exclusive Guide - This guide covers the extraction of ACPI sets, (commonly known as DSDT and SSDTs) using Clover. Overview Extracting DSDT/SSDTs is very easy and has minimal requirements. To extract the DSDT/SSDT, follow the steps below. For Clover...
elitemacx86.com
GUIDE - How to Patch Laptop DSDT and SSDTs
How to Patch Laptop DSDT and SSDTs This guide covers patching Laptop DSDT and SSDTs for macOS/OS X. By following this guide, you'll be able to patch your OEM DSDT/SSDTs. I. Overview To enable macOS features and various hardware and maintain stability, DSDT and SSDTs patching are required...
elitemacx86.com
Finding _OFF Method
Open Terminal
Type:
grep -l Method.*_OFF *.dsl
SSDT-10-SaSsdt .dsl
SSDT-11-SgPch.dsl
SSDT-12-OptTabl.dsl
Finding _INI Method
Type:
grep -l Method.*_INI *.dsl
DSDT.dsl
SSDT-10-SaSsdt .dsl
SSDT-11-SgPch.dsl
SSDT-12-OptTabl.dsl
NOTE:
Method (_INI, 0, NotSerialized) // _INI: Initialize
Store (LTRA, LTRS)
Store (OBFA, OBFS)
The second _INI
Store (LTRB, LTRS)
Store (OBFB, OBFS)
Store (LTRC, LTRS)
Store (OBFC, OBFS)
If (LAnd (LNotEqual (And (ABAR, 0xFFFFC004), 0xFFFFC004), LNotEqual (And (ABAR, 0xFFFFC000), Zero)))
Store (ABAR, BARA)
If (LNotEqual (ABAH, Zero))
Or (BARA, ShiftLeft (ABAH, 0x20), BARA)
Store (Zero, \_SB.PCI0.RP05.PEGP._ADR)
Store (DID1, Index (TLPK, Zero))
Store (DID2, Index (TLPK, 0x02))
Store (DID3, Index (TLPK, 0x04))
Store (DID4, Index (TLPK, 0x06))
Store (DID5, Index (TLPK, 0x08))
Store (DID6, Index (TLPK, 0x0A))
Store (DID7, Index (TLPK, 0x0C))
Store (DID2, Index (TLPK, 0x0E))
Store (DID1, Index (TLPK, 0x0F))
Store (DID2, Index (TLPK, 0x11))
Store (DID3, Index (TLPK, 0x12))
Store (DID2, Index (TLPK, 0x14))
Store (DID4, Index (TLPK, 0x15))
Store (DID2, Index (TLPK, 0x17))
Store (DID5, Index (TLPK, 0x18))
Store (DID2, Index (TLPK, 0x1A))
Store (DID6, Index (TLPK, 0x1B))
Store (DID2, Index (TLPK, 0x1D))
Store (DID7, Index (TLPK, 0x1E))
If (LNotEqual (OSYS, 0x07D9))
PGOF (Zero)
Store (Zero, _STA)
The second _OFF
PGOF (One)
Store (Zero, _STA)
PGOF (0x02)
Store (Zero, _STA)
\_SB.PCI0.RP05.PEGP.SGOF ()
Store (Zero, _STA)
If (LEqual (CTXT, Zero))
If (LNotEqual (GPRF, One))
Store (VGAR, VGAB)
Store (One, CTXT)
SGOF ()
Patches (SSDT)
Patches (DSDT)
For SSDT :
The default patch:
into method label _INI parent_label \_SB.PCI0.PEG0.PEGP insert
begin
//added to turn nvidia/radeon off\n
//External(\_SB.PCI0.PEG0.PEGP._OFF, MethodObj)\n
_OFF()\n
end;
into method label _INI parent_label \_SB.PCI0.RP05.PEGP insert
begin
External(\_SB.PCI0.RP05.PEGP._OFF, MethodObj)\n
_OFF()\n
end;
_OFF()
NOTE:
For DSDT :
For new Laptops
into method label _INI parent_label \_SB.PCI0.GFX0 insert
begin
\n
end;
7. Click on Close.
For DSDT :
The default patch:
into method label _REG parent_hid PNP0C09 insert
begin
If (LAnd(LEqual(Arg0,3),LEqual(Arg1,1)))\n
{\n
\_SB.PCI0.PEG0.PEGP._OFF()\n
}\n
end;
begin
{\n
\_SB.PCI0.RP05.PEGP._OFF()\n
}\n
end;
Method (_REG, 2, NotSerialized) // _REG: Region Availability
If (LEqual (Arg0, 0x03))
Store (Arg1, ECFL)
- The patches will get applied but you’ll need to replace the address of your GPU instead of the default one in both the lines. For e.g \SB.PCI0.RP05.PEGP.
Compiling
Note:
- If you get [Unknown ASL Compiler exception ID] (TGPC [Integer]) error while compiling, remove "External (_SB_.PCI0.PEG0.TGPC, IntObj) // (from opcode)" line from your SSDT.
1. Go to File
2. Select Save as
5. Click on Save
Note:
- It's a good idea to save the patched DSDT and SSDTs in any other location than the original.
Conclusion
1. Mount your ESP
For Clover:
For OpenCore:
NOTE:
Problem Reporting
Details:
- macOS version
- Copy of IOReg
- Kextcache output
- DPCIManager/Status
- About This Mac
- System Information/Graphics/Displays
- For Clover, compress EFI/Clover, and exclude the themes folder.
- For OpenCore, compress EFI/OC.
- Do not include the complete EFI folder.
- Put all files in a folder with your name, compress files as Zip and attach files using site attachments only.
- Do not use any external links.
Credits :
Sample Attachment
