Piker-Alpha has developed a script called ssdtPRGen which will generate a SSDT for your CPU. But for few CPUs which is not listed, or are the latest CPUs from Intel, has not been added to the list. Whenever you try to generate the SSDT, it says "Error: Unknown processor model" and then aborts the process. Here's a quick way to add your CPU to the list and then generate your SSDT.
Determine the Code name of your CPU
Each CPU has it's own code name. The Code name describes the CPU
Determining the CPU code name is pretty easy. Follow the steps below to determine your CPU code name.
Each CPU is different and has different specifications.
Determining the CPU details is pretty easy. Follow the steps below to determine your CPU details.
Details required :
Download the configuration data and command line tools
If you're already having the configuration, skip the below steps and continue here. If not, continue following the steps below.
Open Terminal and download the Piker Alpha's script.
This will download the required files to your user directory.
Adding CPU model
1. Open Finder and in menubar and click on Go to Folder
2. Type ~/Library/ssdtPRGen/
3. Navigate to /Data
4. Open the .cfg file using TextEdit
6. Use the details for your CPU which you collected in the step 2
After adding the details, save the file.
Generating the SSDT
After adding your CPU details, generate the SSDT. Follow How to Generate SSDT for CPU Power Management to generate the SSDT.
Credits :
Pike R. Alpha
- Visit https://ark.intel.com
- Under search field, type your CPU name and press enter.
- A result of your CPU will be displayed.
- Under Essentials, locate the Code Name field and you can find your CPU code name such as Sandy Bridge, Ivy Bridge, Haswell, Broadwell, Skylake Kaby Lake, Kaby Lake-R, Coffee Lake etc.
- Under Performance, you can find the details. The required details are given below
Details required :
Processor Number:
Max TDP:
Low Frequency Mode:
Clock Speed:
Max Turbo Frequency:
No. of Cores:
No. of Threads:
curl -o ~/Library/ssdtPRGen.zip https://codeload.github.com/Piker-Alpha/ssdtPRGen.sh/zip/Beta
unzip -qu ~/Library/ssdtPRGen.zip -d ~/Library/
mv ~/Library/ssdtPRGen.sh-Beta ~/Library/ssdtPRGen
rm ~/Library/ssdtPRGen.zip
Adding CPU model
- Only open the .cfg file followed by your CPU name such as Broadwell, Haswell etc...
- To find "low frequency mode", use AppleIntelInfo.kext.
- Processors without turbo support, set Max Turbo Frequency equal to the Clock Speed. For e.g. i3-7350K, i3-7100 etc..
Generating the SSDT
Credits :
Pike R. Alpha
