How to generate SSDT for Unknown Processor Models using ssdtPRGen script
Piker-Alpha has developed a script called ssdtPRGen which will generate a SSDT for your CPU. But for few CPUs which is not listed, or are the latest CPUs from Intel, has not been added to the list. Whenever you try to generate the SSDT, it says "Error: Unknown processor model" and then aborts the process. Here's a quick way to add your CPU to the list and then generate your SSDT.
Determine the Code name of your CPU
Each CPU has it's own code name. The Code name describes the CPU
Determining the CPU code name is pretty easy. Follow the steps below to determine your CPU code name.
  1. Visit https://ark.intel.com
  2. Under search field, type your CPU name and press enter.
  3. A result of your CPU will be displayed.
  4. Under Essentials, locate the Code Name field and you can find your CPU code name such as Sandy Bridge, Ivy Bridge, Haswell, Broadwell, Skylake Kaby Lake, Kaby Lake-R, Coffee Lake etc.
Determine the CPU Details
Each CPU is different and has different specifications.
Determining the CPU details is pretty easy. Follow the steps below to determine your CPU details.
  4. Under Performance, you can find the details. The required details are given below
Use the above steps and find the details under Performance section.
Details required :
Processor Number:
Max TDP:
Low Frequency Mode:
Clock Speed:
Max Turbo Frequency:
No. of Cores:
No. of Threads:
Download the configuration data and command line tools
If you're already having the configuration, skip the below steps and continue here. If not, continue following the steps below.
Open Terminal and download the Piker Alpha's script.
curl -o ~/Library/ssdtPRGen.zip https://codeload.github.com/Piker-Alpha/ssdtPRGen.sh/zip/Beta
unzip -qu ~/Library/ssdtPRGen.zip -d ~/Library/
mv ~/Library/ssdtPRGen.sh-Beta ~/Library/ssdtPRGen
rm ~/Library/ssdtPRGen.zip
This will download the required files to your user directory.
Adding CPU model
1. Open Finder and in menubar and click on Go to Folder
2. Type ~/Library/ssdtPRGen/
3. Navigate to /Data
4. Open the .cfg file using TextEdit
  • Only open the .cfg file followed by your CPU name such as Broadwell, Haswell etc...
5. Now add missing models like the following format: ## Processor Number, Max TDP, Low Frequency Mode, Clock Speed, Max Turbo Frequency, Cores, Threads
6. Use the details for your CPU which you collected in the step 2
  • To find "low frequency mode", use AppleIntelInfo.kext.
  • Processors without turbo support, set Max Turbo Frequency equal to the Clock Speed. For e.g. i3-7350K, i3-7100 etc..
After adding the details, save the file.
Generating the SSDT
After adding your CPU details, generate the SSDT. Follow How to Generate SSDT for CPU Power Management to generate the SSDT.
Credits :
Pike R. Alpha
I tried to use the guide but my processor is not on the list , any clue how to do it? I found it through the https://ark.intel.com but i can't use it in the cfg
Try using this first:
I did that before and i got the unknownprocessor error that's why i tried this one.
I followed these steps and had the unknown CPU error
Followed the BETA Branch, still get that same error Screen Shot 2020-07-01 at 1.43.26 PM.png
Any help is appreciated.
Followed the BETA Branch, still get that same errorView attachment 2628
For your CPU, you don't need the SSDT. Just use the sample config.plist from here
Thank you for the link. But I am currently running OpenCore. So if you have a link for OC that would be helpful.
Use the normal branch.
angelkiller
