 - Apr 3, 2020
 - Sony VAIO Duo 13 SVD1321Z9E
 - I7 4500U
 - 4400 Hd graphics
 - 10.13.x
 - MacBook Air
Hello everyone, I nearly finished my laptop Hackintosh config and I need to fix my battery. So I followed rehabman tutorial and made a Battery SSDT patch + another patch to make my STA return 0xf instead of something else(like 0xb) and included the rename patch of the value I have edited in the battery ssdt into the config.plist. But it's not working. Under SMCBatterymanagement.kext it just doesn't show any battery and under APCIbatterymanagement.kext I think it does recognize that there's a battery but can't read the battery level (stuck at 0%)
I have linked my SSDT as well as my DSDT in ACPI patched folder (don't worry I don't use it). Any help is appreciated. Thanks in advance.
