Lenovo IdeaPad Z500 Boot time error In Memory Panic Stackshot Succeeded
sinamcr7
Lenovo Z500
Intel Core i7 3632QM
Nvidia Geforce GT-635m
10.13.x
Hi there again
I tried to reinstall and give a larger partition size to Mac OS
it installed successfully but after applying DSDT and SSDT patch + Enabling native power management + Disabling Nvidia I placed patched files all in one time and then restarted it to apply all of them but in the boot process it shows this error :
** In Memory Panic Stackshot Succeeded ** Bytes Traced 13840 **
Attempting system restart... MACH Reboot
it passes error first message quickly so I could just record a video of that
and this is its video
Please help to fix this
Hi there again
No PR files attached.
because I have no access to Mac OS even with USB boot it shows that error and hangs
Use any other system and use the USB files for PR.
PR files doesn't only includes ACPI sets.
but I can't boot into mac anyway to access other needed files how can I do this?
should I reinstall it and do all of these and before restart take those files?
Submit the complete files.
hello i would like to know if you managed to install big sur on lenovo z500 with opencore ... i currently installed catalina with clover from distro niresh
You can send me your EFI folder?
ryusuke17
