Here it is.
Thanks for your help
I put EFI folder on dropbox because I can't upload it to your site :
Check your BIOS settings. For more information on BIOS settings, check this post.
Hi EliteMacx86,
I have checked my bios and everything is good as your guide !
Hi EliteMacx86,
The configuration of your EFI folder. That's the issue.
Is anyone els having problems with thunderbolt three hot plug not working after sleep ?
Here is my information just in case it helps for future troubleshooting.
I have followed this tutorial and I have found that hot plug works perfectly
I am usbinjectall and have a custom SSDT-UIAC.aml and have made sure to include my thunderbolt 3 port
Sleep and wake from sleep is working perfectly
When I wake from sleep thunderbolt 3 no longer detects a device
I have tried leaving a Device plugged into the thunderbolt 3 port, and even when a device is left into the thunderbolt 3 port and is never removed the thunderbolt 3 port stops detecting devices.
I believe it is a sleep problem and not a problem with ThunderboltReset.kext but I wanted to post it here just in case someone els was having this issue.
Thank you to EliteMacx86 for the awesome work !
Thank you for providing the information. Like mentioned in my earlier post, i haven't checked this function yet. But will check it soon and update the thread accordingly.
Thank you to @EliteMacx86 for the awesome work !
You're most welcome :)
UPDATE - Thunderbolt 3 will work after sleep for me, but not with usb 3.0 devices
-Thunderbolt ethernet (working after sleep and hot-plug)
-Thunderbolt to Hdmi (working after sleep and hot-plug)
-Thunderbolt to Display port (working after sleep and hot-plug)
-Thunderbolt to USB 2.0 (working after sleep and hot-plug)
-Thunderbolt to USB 2.0 extender with a usb 3.0 Device (working after sleep and hot-plug)
Thunderbolt to USB 3.0 (working with hot plug) (not working after sleep)
Thunderbolt to thunderbolt (not working after sleep)
Have not tested a EGPU because I do not have one to test.
I hope this testing has helped. So the hot plugging seams to work after sleep, just some things do not
Thanks for the update. I'll check it soon.
Update
- So I believe that I completely fixed it, I changed some bios settings
What sesames to have fixed it for me was changeing adaptor config to no security and auto switch to bios assist enumeration
I hope this helps someone els
scarlywhite
