lenovo v 130 15ikb touchpad not working
installed clover bootloader and files
Remove the DSDT and SSDTs.
Remove the BIOS folder from the drivers directory.
Still the drivers directory is not as per the guide. Remove the following drivers.
  • Fat.efi
  • NvmExpressDxe.efi
  • OpenRuntime.efi
Again, the config.plist is modified and is not as per the guide. Moreover, the invalid kexts are present in the directory which must be removed. I suggest you to read the guide and prepare a configuration according to that. If you cannot understand anything, make sure you ask in the forum. Just attaching the same files with no or minimal edits which is not as per the guide but according to you, will not work.
only three SSDTs for brightness control,function key mapping and olarila ssdt is used
and clover config is changed , efi removed and also kext are sperated into two folder as per guide
  • CLOVE.zip
    CLOVE.zip
remaining attachment and i also tried to place thrird pary kext to S/L/E but it broked my system.so,i restore back to 10.15 folder of clover.
Last login: Sat Apr 18 15:46:00 on ttys001
pops@popss-MacBook-Pro ~ % sudo kextcache -i /
Password:
IOKitWaitQuiet() timed out.
KernelCache ID: 6F1F247EF7A13BDD9A225BB5BBFF217E
The guide says to remove all the kexts directory except "Others". So the 10.15 should not be there. The upload issue has been fixed. You can upload files now. Attach your complete PR files.
Here are few issues
  • Fix your CPU info your profile.
  • Two config.plist are being used and still the config.plist is not as per the guide. The patches in the Acpi are modified.
i have update CPU info and also placed AML in patched folder and also fixes config some about and placed one config.
also complete PR attached
KEXT NOT REMOVED I PLACED THEM ON S/L/E BUT IT BROKE SOUND,BLUETOOTH AND OTHER THINGS SO FOR NOW I PLACED BACK AS EVERYTHING WORK PERFECTLY.
I still see "intel i5" in your profile. You should be able to upload. The server issue has been fixed now.
Still the config.plist is not as per the guide. Use the original config.plist from the guide. Do NOT modify anything. Just replace and attach your complete PR files including kextcache output. Everything should be individual but zipped in one as per PR guide. Do NOT use any other Apps.
XChikuX
