[SOLVED]4 errors in my dsdt on lenovo idepad s145 i7-1065g7
Retry now.
I downloaded this from your link:
Sorry, but I downloaded from iasl.zip and not iasl61.zip.
No issues. Delete the old one. Use the iasl6.1 and disassemble.
I've tried, but the result is the same.
I downloaded iasl 6.1, removed the old one from /usr/bin/, emptied the trash and pasted the new one. Then I retried to disassembly with refs.txt and terminal and I reopened the dsdt.asl file to check errors.
I tried to extract everything with clover and I have many ssdts now. I tried to disassembly and check errors again with dsdt but the result is the same.
Then I'm having a problem to boot from usb installer. It shows me this error: Picture I disabled secure boot, fast
boot, virtualization, intel guard and intel sgxfrom bios settings. I can't install Catalina. I tried to remove and to install clover again. I'm using the MaLdOn's efi folder without his dsdt because he has an i5 8th generation . Please, help me.
Well, i mentioned it yesterday. Even in my notes. For some Laptops, refs.txt is not needed. So just remove that and use "iasl -dl DSDT.aml SSDT*.aml" to disassemble. There should be no any errors.
Delete all the ACPI from origin. Empty the trash and re-extract the ACPI files.
You must enable the Intel Virtualization Technology. Reset the BIOS to defaults and attach the BIOS settings.
We're here to help. Don't worry and don't give up. Start here:
Finally I don't have errors now. Thank you! But how can I solve those warnings and optimizations?
I've uploaded bios pics with default settings but I saw there is an option(OS Feature) that I can enable or not to load default settings. If I disable OS settings and I press default settings, it sets up what I uploaded(UEFI) while if I disable that I saw it sets up legacy boot settings.
Thanks, but I can't find a config.plist for my laptop. I have i7-1065G7 with Iris pro.
Cool.
Thank you!
You're welcome.
Warnings and optimizations can be ignored. Have nothing to do.
Disable Fast.
Disable PXE Boot to LAN.
Disable Secure Boot.
After setting up the BIOS, re-extract and patch your ACPI.
Use UHD 630 config.plist and then check
fierofree
